RocksDB error after 0.16.2 update
Suddenly after update from 0.16.11 to 0.16.12 I got systematic errors with RocksDB. I can no longer send or receive emails. In logs, I can see : RocksDb Error with are more or less
reason = “IO error: While appending to file: /var/lib/stalwart//002267.blob: Disk quota exceeded”, details = “Failed to lock event.”
I tried to launch tasks to reset quotas, but it refuse to create it in webui.
To me seems there is an error with path to blob file with double slash //
The server should continue to function as before
Impossible to receive or send new emails or even create new tasks
Update to 0.16.12 and wait
reason = “IO error: While appending to file: /var/lib/stalwart//002267.blob: Disk quota exceeded”, details = “Failed to lock event.”, causedBy = “crates/store/src/dispatch/lookup.rs:382”, details = “Failed to lock event.”, causedBy = “crates/smtp/src/queue/spool.rs:232”
reason = “IO error: While appending to file: /var/lib/stalwart//002236.blob: Disk quota exceeded”, causedBy = “crates/smtp/src/reporting/dmarc.rs:651”, details = “Failed to write DMARC report”
listenerId = “https”, localPort = 443, remoteIp = 192.168.1.109, remotePort = 55551, reason = “IO error: While appending to file: /var/lib/stalwart//002267.blob: Disk quota exceeded”, causedBy = “crates/jmap/src/registry/mapping/task.rs:348”, accountId = 1, causedBy = “x:Task/set”
SQL
This looks like a file storage issue unrelated to Stalwart’s quotas. The error is coming from RocksDB.
I don’t understand this answer. RocksDB is only used by stalwart executable and error appeared 30 min after update.
So option 1, update is involved in some way
Option 2 : rocksDb should’nt be used because it’s unreliable. I loose receiving email during 2 days on prod server.
How can I recover ? How to prevent it happens again ?
Try delete ur LOG.old.* Files. U dont need them, if its a OS Quota error u should get rid of it. After Updates they usually grow a lot.
Hi, thanks for advice. It wasn’t enough. I had to oversized storage to get more free space than the size of data in /var/lib/stalwart
