Search for Message-ID header not working in Stalwart v0.16
Most of our (www.egroupware.org) code still uses IMAP, but I already use JMAP for push-notifications with Stalwart.
The code was developed with Stalwart v0.12 and I’m currently testing, why some of it is not working with v0.16.
One issue is, when I receive a change via push, I request the Message-ID header (JMAP messageId) and then use that to search for the IMAP uid.
For some reason this search always returns empty in Stalwart v0.16. Here’s the logged IMAP trafik:
C: 4 UID SEARCH RETURN (ALL COUNT) HEADER MESSAGE-ID [email protected]
S: * ESEARCH (TAG "4") UID COUNT 0
S: 4 OK UID SEARCH completed
I also tried search for the Message-ID wrapped with with angle brackets, as it’s used in the header, but not change.
Searching for other headers like Subject works.
Stalwart should return the UID of the message.
It does not find / return anything.
  1. Pick a mail in your INBOX, and get it’s Message-ID
  2. run the IMAP commands in the log with your Message-ID
>> Thu, 11 Jun 2026 09:56:47 +0000
>> Connection to: imap://mail:993/
>> Server connection took 0.0044 seconds.
S: * OK [CAPABILITY IMAP4rev2 IMAP4rev1 ENABLE SASL-IR LITERAL+ ID UTF8=ACCEPT JMAPACCESS AUTH=PLAIN AUTH=OAUTHBEARER AUTH=XOAUTH2] Stalwart IMAP4rev2 at your service.
C: 1 AUTHENTICATE PLAIN [INITIAL CLIENT RESPONSE (username: [email protected])]
S: 1 OK [CAPABILITY IMAP4rev2 IMAP4rev1 ENABLE SASL-IR LITERAL+ ID UTF8=ACCEPT JMAPACCESS IDLE NAMESPACE CHILDREN MULTIAPPEND BINARY UNSELECT ACL UIDPLUS ESEARCH WITHIN SEARCHRES SORT THREAD=REFERENCES LIST-EXTENDED LIST-STATUS ESORT SORT=DISPLAY SPECIAL-USE CREATE-SPECIAL-USE MOVE CONDSTORE QRESYNC UNAUTHENTICATE STATUS=SIZE OBJECTID PREVIEW RIGHTS=texk QUOTA QUOTA=RES-STORAGE] Authentication successful
>> Command 1 took 0.1883 seconds.
>> CACHE: Using the Horde_Imap_Client_Cache_Backend_Cache storage driver.
C: 2 ENABLE QRESYNC UTF8=ACCEPT
C: 3 EXAMINE INBOX (QRESYNC (2394666016 177 1:9))
S: * ENABLED QRESYNC UTF8=ACCEPT
S: 2 OK ENABLE successful.
>> Command 2 took 0.0011 seconds.
S: * 9 EXISTS
S: * FLAGS (\Answered \Flagged \Deleted \Seen \Draft)
S: * 0 RECENT
S: * OK [PERMANENTFLAGS (\Deleted \Seen \Answered \Flagged \Draft \*)] All allowed
S: * OK [UIDVALIDITY 2394666016] UIDs valid
S: * OK [UIDNEXT 10] Next predicted UID
S: * OK [HIGHESTMODSEQ 177] Highest Modseq
S: * OK [MAILBOXID (eaaaaaa)] Unique Mailbox ID
S: 3 OK [READ-ONLY] EXAMINE completed
>> Command 3 took 0.0031 seconds.
>> SEARCH: Expired from cache [INBOX]
>> Command 4 took 0.0019 seconds.
SQL
Let me research this issue around IMAP HEADER search and Message-ID indexing.
This is very revealing. Let me look at the key section where MessageId is indexed (or not indexed) in the Headers search field:
By default non-text headers such as Message Id are not indexed. You have to enable header indexing in order to be able to search for Message-IDs. After enabling indexing you’ll have to trigger a reindex task so the headers of existing mesaages are indexed.
I could only enable indexing all headers, not the individual Message-ID header.
Given the size of some headers this is a huge waste of DB space.
Maybe Message-ID should be it’s own indexable header like Subject or From, it can still be off by default …
Ralf
Users rarely search by Message ID or any other internal headers, that is why it’s disabled by default.
For your IMAP client you should use UID/UIDVALIDITY or preferably the OBJECTID extension to identify messages.
