Server not accessible in recovery mode after a blob store misconfiguration
I recently got locked out by making a typo in the blob store configuration.
I lost access to the server in recovery mode via the WebUI and stawart-cli (I did not try the apply command since I was playing around locally and did not have a snapshot file).
Server accessible via the WebUI and stawart-cli in recovery mode when the blob storage is misconfigured.
Error in the WebUI and stalwart-cli.
  1. Configure Stalwart v0.16.23 with a blob store and ensure the connection succeeds.
  2. Update the blob store configuration and restart Stalwart in recovery mode.
ERROR S3 error (store.s3-error) reason = "<?xml version="1.0" encoding="UTF-8"?><Error><Code>SignatureDoesNotMatch</Code><Message></Message><RequestId>...</RequestId><HostId>...</HostId></Error>", code = 403, causedBy = "crates/store/src/dispatch/blob.rs:52", causedBy = "crates/common/src/network/mta.rs:452", details = "Failed to load spam filter model", causedBy = "crates/common/src/manager/boot.rs:222"
ERROR Resource error (resource.error) reason = S3 error (store.s3-error) { reason = "<?xml version="1.0" encoding="UTF-8"?><Error><Code>SignatureDoesNotMatch</Code><Message></Message><RequestId>...</RequestId><HostId>...</HostId></Error>", code = 403, causedBy = "crates/store/src/dispatch/blob.rs:52" }, url = "https://github.com/stalwartlabs/webui/releases/latest/download/webui.zip", details = "Failed to unpack application for prefixes: admin, account, no bundle is available to serve"
Recovery mode does not fully isolate the server from a broken blob store. The webui bundle is treated as an Application object, and unpacking it is not gated on recovery mode: start_services() always calls applications.unpack_all(), which first checks the blob store for a cached copy of the bundle before falling back to downloading it from GitHub. When the blob store is misconfigured, that cache lookup fails with the S3 error you saw, and if no bundle is cached yet (or the cached entry can’t be read), the server has nothing to serve for /admin or /account, so the WebUI itself comes up blank in recovery mode too.
The JMAP management API (which stalwart-cli talks to directly, not through the webui bundle) is not supposed to depend on the blob store being healthy though, so a BlobStore object can normally still be corrected via stalwart-cli even while the WebUI bundle fails to load. If you found the CLI itself refusing to connect or authenticate under the same conditions, that’s beyond what’s documented and would need a closer look at your specific setup (recovery admin credentials, listener state, etc.) rather than something covered by current docs.
For reference, the recovery mode mechanism and the STALWART_RECOVERY_ADMIN fallback credential are described here: Recovery mode | Stalwart
Fixed in v0.16.25 (will be released today).
