`stalwart` does not build with rocksdb `11.x.x` libraries
I am trying to build stalwart from source using 11.1.2 of rocksdb however it fails to compile and build.
Should be able to compile and use rocksdb 11 as backend
stalwart fails to compile with rocksdb 11 libraries
  1. build rocksdb 11 from source
  2. export ROCKSDB_INCLUDE_DIR=/path/to/rocksdb11/build/include
  3. export ROCKSDB_LIB_DIR=/pathj/to/rocksdb11/build/lib
  4. build stalwart from source (tag: v0.16.11)
   Compiling rocksdb v0.24.0
   Compiling virtue v0.0.18
   Compiling decancer v3.3.3
error[E0425]: cannot find function `rocksdb_options_set_skip_checking_sst_file_sizes_on_db_open` in crate `ffi`
    --> /nix/var/nix/builds/nix-47127-4213388205/stalwart-0.16.11-vendor/source-registry-0/rocksdb-0.24.0/src/db_options.rs:2716:18
2716 |             ffi::rocksdb_options_set_skip_checking_sst_file_sizes_on_db_open(
     |                  ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ not found in `ffi`
   Compiling constant_time_eq v0.3.1
   Compiling prometheus v0.14.0
   Compiling totp-rs v5.7.2
error[E0061]: this function takes 5 arguments but 6 arguments were supplied
  --> /nix/var/nix/builds/nix-47127-4213388205/stalwart-0.16.11-vendor/source-registry-0/rocksdb-0.24.0/src/slice_transform.rs:49:13
49 |             ffi::rocksdb_slicetransform_create(
56 |                 Some(slice_transform_name_callback),
   |                 ----------------------------------- unexpected argument #6 of type `Option<unsafe extern "C" fn(*mut c_void) -> *const i8 {slice_transfo_`
note: function defined here
  --> /nix/var/nix/builds/nix-47127-4213388205/source/target/aarch64-apple-darwin/release/build/librocksdb-sys-2aa72d5739d9444c/out/bindings.rs:3:164766
 3 | ...ut libc :: c_char) ; } unsafe extern "C" { pub fn rocksdb_slicetransform_create (state : * mut libc :: c_void , destructor : :: s...
help: remove the extra argument
55 -                 None,
56 -                 Some(slice_transform_name_callback),
55 +                 None,
   Compiling jsonwebtoken v10.4.0
   Compiling bincode_derive v2.0.1
Some errors have detailed explanations: E0061, E0425.
For more information about an error, try `rustc --explain E0061`.
Built from source
related: Update Request: rocksdb 10.10.1 → 11.1.2 · Issue #536878 · NixOS/nixpkgs · GitHub
This is coming from the rocksdb Rust crate (v0.24) that Stalwart depends on, not from Stalwart’s own code. That crate’s FFI bindings were generated against an older librocksdb release, so its function signatures (e.g. rocksdb_slicetransform_create) and expected symbols (e.g. rocksdb_options_set_skip_checking_sst_file_sizes_on_db_open) don’t match RocksDB 11.x’s C API, which is why linking against a self-built RocksDB 11 fails even though Stalwart itself hasn’t changed anything.
Stalwart’s store crate pins rocksdb = "0.24" with the multi-threaded-cf feature, and that crate normally vendors/bundles its own compatible RocksDB version rather than expecting an arbitrary external one supplied via ROCKSDB_INCLUDE_DIR/ROCKSDB_LIB_DIR. Until that crate is bumped to a version whose bindings support RocksDB 11’s API, building against externally-supplied RocksDB 11 libraries won’t work, this is a compatibility gap in the upstream rust-rocksdb bindings rather than a configuration issue you can work around from Stalwart’s side. Building with the bundled RocksDB (i.e. not overriding ROCKSDB_INCLUDE_DIR/ROCKSDB_LIB_DIR) should still work fine.
