Stalwart-migrate 1.0.0: Registry deserialization errors during v0.16.27 upgrade
I’m reporting an issue encountered while upgrading my Stalwart server from v0.16.27 to v1.0.0.
Environment:
  • OS: Linux (systemd installation)
  • Source version: Stalwart 0.16.27
  • Migration tool: stalwart-migrate 1.0.0
  • Database: RocksDB
  • Blob storage: Local RocksDB
  • Migration performed offline, with the original server stopped
Issue:
The stalwart-migrate prepare command failed with a registry.deserialization-error, preventing the migration from proceeding.
My Stalwart 0.16.27 installation had been functioning normally before the upgrade.
I compiled a modified version of the migration tool with additional diagnostic logging and scanned the registry.
The scan identified 21 unreadable entries out of 2,870, including:
  • Log
  • MtaDeliverySchedule
  • MtaExtensions
  • MtaHook
  • MtaOutboundStrategy
  • MtaStageAuth
  • MtaStageConnect
  • OidcProvider
  • ReportSettings
  • WebHook
I confirmed that the registry deserialization source files bundled with the migrator match those from Stalwart v0.16.27.
Workaround:
I modified crates/source-v016/src/adapter/registry.rs to skip entries that fail deserialization rather than aborting the migration.
With this modification, the migration completed successfully:
  • 3,630 emails migrated
  • 1 account migrated
  • 2,698 blobs copied
  • Full verification: 0 mismatches, 0 unexplained differences
The skipped registry entries were not migrated, so some configuration settings may still need manual restoration.
Suggestion:
It would be useful if stalwart-migrate could handle unreadable legacy registry entries more gracefully, for example by allowing users to skip them with an explicit warning instead of aborting the entire migration.
stalwart-migrate prepare should successfully read and convert the registry from Stalwart 0.16.27 to 1.0.
If a legacy registry entry cannot be deserialized, the migration tool should report its type and ID and ideally allow skipping it with a warning
stalwart-migrate 1.0.0 fails during prepare with registry.deserialization-error.
I identified 21 unreadable registry entries out of 2,870, including Log, MtaDeliverySchedule, MtaHook, MtaExtensions, MtaOutboundStrategy, OidcProvider and others.
I modified crates/source-v016/src/adapter/registry.rs to skip unreadable entries.
After this modification, the migration completed successfully:
One security concern: the original error message includes the complete Base64-encoded registry value, which in my case contained a PEM private key.
  1. Install Stalwart 0.16.27 with RocksDB on Linux.
  2. Install stalwart-migrate 1.0.0.
  3. Execute:
    stalwart-migrate prepare --source /etc/stalwart/config.json --state /var/lib/stalwart-migrate
  4. Observe registry.deserialization-error.
  5. The same issue occurs with an offline copy of the RocksDB database.
  6. Patching the registry iterator to skip entries that fail deserialization allows the migration to complete.
The issue depends on the stored registry entries, so it may not reproduce on a fresh installation.
ERROR stalwart_migrate: command failed
error=account error: Registry deserialization error
(registry.deserialization-error)
causedBy = vendor/v016/crates/store/src/registry/mod.rs:96
value = [REDACTED: contains PEM private key]
Diagnostic:
REGISTRY DECODE FAILED: type=Log, id=20080258862541
REGISTRY DECODE FAILED: type=MtaDeliverySchedule, id=20080258862541
Registry scan:
21 errors, 2870 entries checked
After applying the skip patch:
run finished status=ok
verify: 1 accounts checked, 0 mismatches, 0 unexplained (ok)
v1.x
The docs don’t describe a way to skip unreadable 0.16 registry entries, and they don’t mention this error.
Thanks for the detailed report. The docs don’t cover this failure, and I couldn’t find anything about how stalwart-migrate is meant to handle registry entries that fail to deserialize.
What I could confirm:
  • registry.deserialization-error is documented as “A registry entry could not be deserialized; it may have been written by an incompatible version of the server” (events reference).
  • The upgrade guide describes prepare as reading the 0.16 settings and converting them to 1.0. It doesn’t mention skipping unreadable entries, and it gives no recovery path for this error (upgrade guide).
Your skip patch moved the migration forward, but the 21 skipped entries (Log, MtaHook, OidcProvider, WebHook and so on) were not converted. Compare your 0.16 settings with the 1.0 server after the migration and recreate anything missing by hand.
The error message including the full Base64 registry value, which here contained a PEM private key, is worth flagging. Treat any logs or terminal output from the failed runs as sensitive, and consider rotating that key.
This has been fixed. Please try again with stalwart-migrate 1.0.1 which is being compiled now.
