When migrating from 0.16.27 to 1.0.0 with stalwart-migrate, run --final copies and finalizes with 0 errors, but verification then reports 13 unexplained mismatches, all of type span. Because of this the migration is never marked done. Rerunning run --final with the source stopped and unchanged reports the same 13 mismatches. --allow-errors doesn’t help because these are verification mismatches, not errors.
There are no mail, account or settings mismatches; only spans are affected. This may share a root cause with #2040, where the v1 boot during migration cleans up objects that verify then reports as missing. I haven’t confirmed that.
Environment:
- Source: Stalwart 0.16.27 (Docker stalwartlabs/stalwart:v0.16, enterprise build), RocksDB store
- Target: new, empty RocksDB store for 1.0.0
- Tool: stalwartlabs/stalwart-migrate:1.0.0, run as a Docker Compose service as described in the installation docs
- Single node, 8 accounts, ~2 GB of data
One of these:
- the incremental final run recopies the differing spans so verification passes, or
- trace mismatches count as explained by the documented trace limitation, so they don’t block finalization.
run --final finishes the copy and finalize with status=ok and 0 errors, but verification fails with 13 span mismatches and the final run isn’t marked done. Rerunning gives the same result every time. The only way forward seems to be starting over with --exclude telemetry.
- Run prepare and accept every default (all categories, recommended default policy, accept the OAuth registration change, grant new permissions). Result: 0 errors.
- Run run while 0.16 is still running. Result: status=ok, 0 errors, 6,634 emails, 8 accounts.
- Stop 0.16 and run run --final. The 30-second source watch passes, and copy/finalize returns status=ok with 0 errors. Verification then fails.
- Rerun run --final --yes with 0.16 still stopped. Same 13 mismatches.
INFO migrate::orchestrator: run finished run_id=2 status=ok stats={“accounts_unchanged”:8,“errors”:0,“global_records”:16,“issues”:38,…}
INFO migrate::orchestrator::verify: verify finished run_id=3 status=failed accounts_checked=8 mismatches=13 unexplained=13
ERROR migrate::orchestrator: finalize completed but verification failed: the final run is not marked done; fix the reported mismatches and repeat the command (run --final, or rollback with the same --state)
INFO migrate::orchestrator: run finished run_id=4 status=ok stats={“accounts_unchanged”:8,“errors”:0,“global_records”:16,“issues”:38,…}
INFO migrate::orchestrator::verify: verify finished run_id=5 status=failed accounts_checked=8 mismatches=13 unexplained=13
stalwart-migrate report --severity verify:
run severity category account object id message
3 verify mismatch - span 333905986825891328 differs in the target
3 verify mismatch - span 333921088201438208 differs in the target
3 verify mismatch - span 333936189004462080 differs in the target
3 verify mismatch - span 333951287894884864 differs in the target
3 verify mismatch - span 333966388794378752 differs in the target
3 verify mismatch - span 333981490178316288 differs in the target
3 verify mismatch - span 333996588661894144 differs in the target
3 verify mismatch - span 334011689781591552 differs in the target
3 verify mismatch - span 334026791274583040 differs in the target
3 verify mismatch - span 334041892272651264 differs in the target
3 verify mismatch - span 334056991104354304 differs in the target
3 verify mismatch - span 334072091934657536 differs in the target
3 verify mismatch - span 334081053583152128 differs in the target
v1.x
