Hmm, I tried to proceed, but:
2026-10-26T18:28:09.162489Z WARN hickory_net::dnssec: response does not contain NSEC or NSEC3 records. Query: Query { name: Name("."), query_type: DNSKEY, query_class: IN } response: DnsResponse { message: Message { metadata: Metadata { id: 12548, message_type: Response, op_code: Query, authoritative: false, truncation: false, recursion_desired: false, recursion_available: false, authentic_data: false, checking_disabled: false, response_code: NXDomain }, queries: [Query { name: Name("."), query_type: DNSKEY, query_class: IN }], answers: [], authorities: [], additionals: [], signature: None, edns: None }, buffer: [49, 4, 128, 3, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 48, 0, 1] }
2026-10-26T18:28:09.417364Z INFO migrate::orchestrator::account: account pass started accounts=9 removed=0
2026-10-26T18:28:09.660367Z INFO migrate::orchestrator::finalize: finalizing target accounts=9
2026-10-26T18:28:09.664586Z INFO migrate::orchestrator: run finished run_id=6 status=ok stats={"accounts_delta":0,"accounts_failed":0,"accounts_full":0,"accounts_removed":0,"accounts_unchanged":9,"accounts_wiped":0,"blob_bytes":0,"blobs_copied":0,"bytes_written":0,"emails_written":0,"errors":0,"global_deleted":0,"global_records":0,"issues":35,"log_rows":0,"objects_deleted":0,"objects_skipped":0,"objects_written":0,"registry_deleted":0,"registry_dropped":0,"registry_written":0}
2026-10-26T18:28:38.983954Z INFO migrate::orchestrator::verify: verify finished run_id=7 status=failed accounts_checked=9 mismatches=5 unexplained=4
2026-10-26T18:28:38.984020Z ERROR migrate::orchestrator: finalize completed but verification failed: the final run is not marked done; fix the reported mismatches and repeat the command (run --final, or rollback with the same --state)
run 6: ok ({"accounts_delta":0,"accounts_failed":0,"accounts_full":0,"accounts_removed":0,"accounts_unchanged":9,"accounts_wiped":0,"blob_bytes":0,"blobs_copied":0,"bytes_written":0,"emails_written":0,"errors":0,"global_deleted":0,"global_records":0,"issues":35,"log_rows":0,"objects_deleted":0,"objects_skipped":0,"objects_written":0,"registry_deleted":0,"registry_dropped":0,"registry_written":0})
verify: 9 accounts checked, 5 mismatches, 4 not explained by earlier reports (failed)
finalize completed but verification failed: the final run is not marked done. Fix the reported mismatches (stalwart-migrate report --severity verify) and run --final again.
And there are some more errors:
run severity category account object id message
5 verify mismatch - x:SpamTrainingSample 328762709843335680 the converted source object is missing in the target
5 verify mismatch 31 email 44518 differs in the target: keywords
5 verify mismatch 31 email 58658 differs in the target: keywords
5 verify mismatch 31 email 70616 differs in the target: keywords
5 verify mismatch 31 email 70894 differs in the target: keywords
Back to v0.16 for now.
