Hello,
Would it be possible to add support for customizing the resource URL used by the WebUI admin dashboard?
The goal is to enable deployment of Stalwart in offline or air-gapped environments, where external resource URLs are not accessible.
Providing this through either an environment variable or a setting in config.json would be greatly appreciated.
Thank you for your consideration.
Best regards,
