Does Stalwart support a prefix for the WebUI e.g. /stalwart/admin and /stalwart/account instead just /admin and /account?
Just adding it as additional urlPrefix seems not to work, Stalwart responds with 404 not found
The answer is yes, custom prefixes are supported – but there’s an important nuance about how the bundle’s internal routing works. The server rewrites the <base href="/"> tag in index.html to match whatever mount path you configure, so the same bundle can be served from any path. However, the WebUI SPA itself uses its own internal routing (e.g. navigating to /admin/... sub-routes), and it must be built expecting the base path you set.
Here is what the docs say concretely:
- The
urlPrefix field on the Application object is a String[]. You can set it to e.g. ["/stalwart/admin", "/stalwart/account"] to mount the WebUI at those paths instead of the defaults.
- The server automatically rewrites the
<base href="/"> tag in the bundle’s index.html to match the configured mount path, so assets resolve correctly without repackaging.
- The constraint is that the paths must not collide with JMAP/WebDAV/
.well-known endpoints, and they must not collide with each other across Applications.
Why you’re getting 404: The most likely cause is that urlPrefix accepts a JSON array (e.g. ["/stalwart/admin", "/stalwart/account"]), not two separate entries. Also confirm your HTTP listener is actually receiving traffic at that path – if a reverse proxy is stripping the prefix before it reaches Stalwart, the server would never see the prefixed path.
You can update the Application object via the WebUI at Settings > Web Applications, or via the JMAP API (x:Application/set with an update operation changing the urlPrefix array).
Relevant docs: Applications overview and the Application object reference.
According to `stalwart-cli snapshot Application` I have the following set:
"@type": "create",
"object": "Application",
"value": {
"application-iuhrvwukaaab": {
"description": "Stalwart Web Interface",
"urlPrefix": {
"/admin": true,
"/account": true,
"/stalwart/admin": true,
"/stalwart/account": true
"enabled": true,
"autoUpdateFrequency": 2592000000,
"resourceUrl": "https://github.com/stalwartlabs/webui/releases/latest/download/webui.zip",
"unpackDirectory": null
Do I need to reload anything?
`/stalwart` is proxied by Nginx into the stalwart container.
Trying to `curl -i https://boulder.egroupware.org/stalwart/admin/` gives the following response:
HTTP/2 404
server: nginx/1.30.2
date: Fri, 05 Jun 2026 12:54:10 GMT
content-type: application/problem+json
content-length: 120
{“type”:“about:blank”,“status”:404,“title”:“Not Found”,“detail”:“The requested resource does not exist on this server.”}
Any ideas?
Multi-segment prefixes like /stalwart/admin do not work in 0.16: the router matches on the first path segment only, so a request to /stalwart/admin is dispatched as the prefix “stalwart” while the app is registered under the full “stalwart/admin”, and the lookup misses, giving you the 404. Only single-segment prefixes are supported, which the docs do not make clear.
The workaround is to use a single-segment prefix such as /stalwart and proxy that in your reverse proxy; after changing the Application object you do need to run a settings reload for it to take effect. If you genuinely need the two-level /stalwart/admin layout, that would require a code change.
Ok, that got me a lot further
I changed add just /stalwart as additional URL for the WebApp, reloaded the settings and set the following environment variable for the Docker container:
services:
mail:
image: stalwartlabs/stalwart:v0.16-alpine
container_name: stalwart-mail
environment:
- STALWART_PUBLIC_URL=https://boulder.egroupware.org
ports:
- "8081:8080"
And the following proxy in nginx.conf
server {
# set Docker's resolver so Nginx can detect changed IP's of containers
resolver 127.0.0.11 valid=60s;
# services need to be set for Nginx to resolve them again
set $mail mail;
listen 443 ssl http2 default_server;
ssl_certificate /etc/ssl/private/certificate.pem;
ssl_certificate_key /etc/ssl/private/certificate.pem;
server_name boulder.egroupware.org;
location ~^/(stalwart|jmap|.well-known/jmap|logo|api/(discover|auth|schema|oauth|principal|telemetry|reload|settings|account|dns)|login|auth ) {
proxy_read_timeout 3600;
proxy_http_version 1.1;
proxy_set_header Host $http_host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass https://$mail;
Now I can login successful and everything seems to work
Locking at the browser I can see a single URL to still fail, thought it’s proxied into the Stalwart container:
curl -i https://boulder.egroupware.org/logo/
HTTP/2 404
date: Sun, 07 Jun 2026 07:33:23 GMT
content-length: 120
{"type":"about:blank","status":404,"title":"Not Found","detail":"The requested resource does not exist on this server."}
curl -i http://localhost:8081/logo/
HTTP/1.1 404 Not Found
content-length: 120
date: Sun, 07 Jun 2026 07:33:29 GMT
So far this seems just odd, but has no negativ effect as far as I can tell …
Any idea why the WebApp requests /logo/ but the container does not respond to it?
Ralf
