Stalwart v0.16.18 ASN & GeoIP URLs missing
  • ASN & GeoIP: Default data source URLs now point at the ip-location-db GitHub releases, as the previously used npm packages are no longer updated. Existing installations keep their configured URLs and should update them following the ASN and GeoIP documentation.
Unfortunately the linked documentation does NOT include a GitHub URL, but still https://cdn.jsdelivr.net/npm/.
Can you provide the new URLs, or update the linked docu, if possible also with how to set the URLs via curl and the provided JSON.
Ralf
It should be available in a few minutes, the CI job is rebuilding the site.
