Subaddressing Doc of v.16 is wrong
in the doc it told :
"match": [{"if": "matches('^([^.]+)\\.([^.]+)$', rcpt)", "then": "$2"}],
but it should be
"match": [{"if": "matches('^([^.]+)\.([^.]+)$', rcpt)", "then": "$2"}],
The doc is actually correct as written. That block is a JSON object (submitted via the JMAP API or WebUI, not a raw expression string), so the regex has to be JSON-escaped: to represent a single backslash character (for \. in the regex) inside a JSON string you need \\.. If you used the single-backslash version you posted, the JSON parser would interpret \. as an invalid escape sequence.
So "matches('^([^.]+)\\.([^.]+)$', rcpt)" in the JSON snippet does correctly encode the regex ^([^.]+)\.([^.]+)$ once JSON-decoded, matching a local part like alias.user and capturing user as group 2. You can see this pattern on the Subaddressing docs page.
Can’t follow the bot if I try the current Doc example it do not work.
If you remove the / it work.
The docs show examples for the CLI which require escaping, on the WebUI they don’t. I just added a note to the documentation explaining this.
Perfect thanks a lot :slight_smile:
