Temporary server failure. If the problem persists, contact your administrator
Login in into 8080:/login, returns “Temporary server failure. If the problem persists, contact your administrator.”
However server logs /stalwart/todays date - says “auth ok and no more”
I did restart server and problem stays
How to locate problem?
Let me look into this error message and what might cause it.
Based on the source code, the “Temporary server failure” message from the login page is triggered by one of three specific conditions in the browser-side login JavaScript:
  1. Malformed/unexpected response from the /api/auth endpoint (the server returned something other than a valid JSON tagged union).
  2. Missing client_code in an authenticated response.
  3. Invalid or missing redirect_uri – the login page was opened without a proper redirect_uri query parameter.
Since your logs show “auth ok” (meaning authentication itself succeeded), the most likely culprit is condition #3: the WebUI login page is being accessed without a valid redirect_uri. This happens when you navigate directly to :8080/login rather than through the proper OAuth flow that the WebAdmin WebUI initiates (which includes redirect_uri, client_id, and a PKCE code_challenge as query parameters).
What to try:
  • Access the admin panel via its normal entry point (e.g., http://yourserver:8080 or https://yourserver/admin), not by going directly to /login. The WebUI generates the correct OAuth parameters before redirecting you to the login page.
  • If you are accessing /login directly, check the URL – it should have query parameters like ?client_id=webadmin&redirect_uri=...&code_challenge=.... If those are missing, the login will always fail after auth succeeds, because there is nowhere valid to redirect the authorization code.
  • Check your browser’s developer console (F12 > Console tab) – the login page logs the exact reason (e.g., "Invalid or missing redirect_uri:") before showing the generic error message to the user.
The relevant API docs: API Endpoints | Stalwart
Try to path /admin/login
Resolves it and saved me from hart attack. Thanks
I was trying to fix this thing for weeks
After setup wizard I couldn’t login anyhow and I was tweaking traefik endlessly to get it working. It turns out it was incredibly simple routing quirk on the frontend all along.
I really think its a bug that has to be resolved
This can happen at https://mail.example.com/login as well. I can see in the logs I’ve authenticated correctly:
INFO Authentication successful (auth.success) listenerId = "https", localPort = 443, remoteIp = 95.209.131.1, remotePort = 54288, accountName = "[email protected]", accountId = 2
and I’ve received the client_code:
TRACE HTTP response body (http.response-body) listenerId = "https", localPort = 443, remoteIp = 95.209.131.1, remotePort = 54288, contents = "{"type":"authenticated","client_code":"DEADbeefAvHADuierMzQ8pexQdAzJjBbtoOXz"}", code = 2
00, size = 81
This is on a new–ish install of Stalwart 16 (from May 7). The /admin/login/ path works.
I have used the developer tools and the error message on the login page says;
Invalid or missing redirect_uri: null Error: missing redirect_uri
