Tokio-rt-worker divide by zero panics
An accidental discovery while testing Vandelay, but changing the Stalwart HTTP rate limit (Network > Services > HTTP > Security > Rate Limit > Authenticated) units to Milliseconds, causes Tokio “Divide by Zero” crashes, and appears to be completely unrecoverable, as neither the WebUI, CLI or recovery mode are usable once this occurs.
Restoring or recreating the data store is the only solution I found.
Error message is:
thread ‘tokio-rt-worker’ (8) panicked at crates/store/src/dispatch/lookup.rs:304:27:
attempt to divide by zero
There should be no divice by zero panics, and the WebUI, CLI and recovery mode should work.
  1. From a running Stalwart configuration (please backup before you try this), navigate to Network > Services > HTTP > Security > Rate Limit > Authenticated and change the units to Milliseconds and save.
  2. Restart stalwart, and the WebUI and CLI will no longer be available. The panics will be written to the (docker) log.
Meilisearch
Let me look at the relevant source code to understand this bug.
The panic is on line 304: let range_start = now / rate.period.as_secs();. When the rate limit period is set to milliseconds (e.g. “1 millisecond”), rate.period.as_secs() returns 0 (since it’s less than one second), causing an integer divide-by-zero panic. This crash then renders the HTTP listener unresponsive, making the WebUI, CLI, and recovery mode all inaccessible.
The panic is a confirmed bug. Here is what is happening:
Root cause: Line 304 of crates/store/src/dispatch/lookup.rs computes the rate-limit time bucket with:
When the rate limit period is stored in milliseconds and then converted to seconds with .as_secs(), a sub-second Duration produces 0 from .as_secs() – and dividing by zero panics the Tokio worker thread. Because the HTTP API itself goes through the rate-limit path, every subsequent request also panics, making the WebUI, CLI, and recovery mode all unreachable.
Immediate workaround: As you found, restoring or recreating the data store is the only recovery path once the bad value is persisted. Before doing that again, you can try editing the store record directly (e.g. in PostgreSQL) to reset the rate-limit period to a sane value (seconds, not milliseconds).
To avoid it in the future: Do not set the HTTP Authenticated Rate Limit period unit to Milliseconds. Use Seconds (or larger). Any sub-second period will produce the same divide-by-zero crash.
This is a genuine bug – the code should guard against a zero-valued period (e.g. with a checked_div or by validating at configuration-save time that the period is at least 1 second). The issue is clearly reproducible and worth flagging; a human maintainer will follow up on this thread.
This has been fixed on the main branch. The fix will be included in v0.16.8.
This appears to still be present in 0.6.11.
@wryfi I just tested setting both IMAP and HTTP rate limit units to Milliseconds on a configured v0.16.13 instance, without issue.
Happy to test again, but what settings did you use to trigger this?
i confirm still see this issue on 0.16.16 but in JMAP blob upload quota when uploadTtl is less than 1 second.
Please provide the full panic message including the line number.
I tried this on v0.16.16, but could not reproduce.
Network > Services > JMAP > Limits > Upload Limits > Expire After: 5 Milliseconds.
I then restarted stalwart, but everything is still working for me. Was this the correct setting?
Yes, that’s the correct parameter. I should clarify I was importing mailboxes using vandelay. Below is the panic message:
Aug 06 18:09:03 hostname stalwart_1[54787]: thread 'tokio-rt-worker' (2) panicked at crates/common/src/storage/blob.rs:40:31:
Aug 06 18:09:03 hostname stalwart_1[54787]: attempt to divide by zero
As soon as I set the value to 1 second, everything went fine.
This has been fixed now but you can’t set a 0 value there, the next release won’t allow it. Use an account with admin privileges if you are having rate limiting issues.
Just to clarify and be sure there is no misunderstanding: it wasn’t set to 0, it was set to 1ms.
I’m no rust expert but I think this line [1] round 1ms to 0 second.
[1] stalwart/crates/common/src/config/mailstore/jmap.rs at main · stalwartlabs/stalwart · GitHub
