Trivy scan reported several security issues
Trivy scan reported several security issues,
Select alert #12
Asymmetric Private Key
High
#12 opened 3 hours ago • Detected by Trivy in crates/…/task_manager/dkim.rs :617
main
Select alert #11
High
#11 opened 3 hours ago • Detected by Trivy in crates/…/task_manager/dkim.rs :587
main
Select alert #10
High
#10 opened 3 hours ago • Detected by Trivy in crates/…/network/webpush.rs :263
main
Select alert #9
High
#9 opened 3 hours ago • Detected by Trivy in crates/…/network/webpush.rs :252
main
Select alert #8
High
#8 opened 3 hours ago • Detected by Trivy in crates/…/network/webpush.rs :246
main
Select alert #7
High
#7 opened 3 hours ago • Detected by Trivy in crates/…/network/webpush.rs :240
main
Select alert #6
High
#6 opened 3 hours ago • Detected by Trivy in crates/…/config/mod.rs :196
main
Select alert #5
High
#5 opened 3 hours ago • Detected by Trivy in crates/…/config/mod.rs :189
main
Select alert #4
High
#4 opened 3 hours ago • Detected by Trivy in crates/…/config/mod.rs :183
main
Select alert #3
High
#3 opened 3 hours ago • Detected by Trivy in crates/…/config/mod.rs :177
main
Select alert #1
lz4_flex: lz4_flex’s decompression can leak information from uninitialized memory or reused output buffer
High
#1 opened 3 hours ago • Detected by Trivy in Cargo.lock :4353
main
Select alert #2
Rand is unsound with a custom logger using rand::rng()
Low
#2 opened 3 hours ago • Detected by Trivy in Cargo.lock :6095
They work as expected? or they are vulns need to fix?
All of these are false positives triggered by Trivy’s generic secret-scanning pattern matching, not actual leaked keys or unpatched vulnerabilities.
The “Asymmetric Private Key” alerts (#3-#12): every one of these is a hardcoded test/example PEM key embedded in unit test code (dkim.rs, webpush.rs, config/mod.rs), used to test key parsing (RSA, EC/ECDSA, PKCS8, etc.). They’re not production secrets and never touch a live deployment; Trivy just pattern-matches any -----BEGIN ... PRIVATE KEY----- block regardless of context. These are safe to ignore or suppress in your scanner config.
#1 (lz4_flex uninitialized memory advisory): this is a transitive dependency pulled in via Cargo.lock, flagged for a known decompression issue in older lz4_flex versions. Whether it’s exploitable depends on whether lz4_flex is actually used to decompress untrusted input in Stalwart’s code paths, and whether the locked version is patched. Worth checking the current Cargo.lock version against the advisory’s fixed version.
#2 (rand unsound with custom logger): this is a Low-severity advisory about a specific misuse pattern (rand::rng() with a custom logger), also from a transitive dependency, not something Stalwart’s own code exercises directly.
None of this indicates an actively exploitable vulnerability from an operator’s perspective; the private-key alerts specifically are text fixtures, not credentials. If you want the dependency advisories addressed, worth flagging directly so someone can check the exact locked versions.
