Auto-banned IPs not taking effect until node restarted
IPs blocked via the Auto banning port scanner are not taking effect without a manual node reboot. Action → Reload → Blocked IPs list has no effect.
When a blocked IP address is added to the list due to a security scan, it should immediately take effect without further intervention.
The IP continues to scan and the log file continues to report banning it as if it was a new event.
  1. Wait for a scanner to start scanning a node
  2. Observe the log entry to confirm the IP has been blocked
  3. Check the block list, confirm the IP is there
  4. Actions → Reload → Blocked IPs list - does not have an effect as the log entries continue
  5. Restart the node, the port scanning log entries stop, assuming they are now in effect
Truncated to last 3 entries for each IP
2026-05-27T06:10:37Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 150.109.104.66, remotePort = 52418, remoteIp = 150.109.104.66, path = "/demo/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php"
2026-05-27T06:10:42Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 150.109.104.66, remotePort = 52418, remoteIp = 150.109.104.66, path = "/cms/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php"
2026-05-27T06:10:46Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 150.109.104.66, remotePort = 52418, remoteIp = 150.109.104.66, path = "/crm/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php"
2026-05-27T10:18:52Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 195.178.110.199, remotePort = 38166, remoteIp = 195.178.110.199, path = "/wp-json/gravitysmtp/v1/tests/mock-data"
2026-05-27T10:18:52Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 195.178.110.199, remotePort = 38236, remoteIp = 195.178.110.199, path = "/wp-content/mysql.sql"
2026-05-27T10:18:52Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 195.178.110.199, remotePort = 38218, remoteIp = 195.178.110.199, path = "/wp-json/wp/v2/users"
2026-05-27T17:25:58Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 101.47.8.187, remotePort = 58518, remoteIp = 101.47.8.187, path = "/apps/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php"
2026-05-27T17:25:59Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 101.47.8.187, remotePort = 58518, remoteIp = 101.47.8.187, path = "/app/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php"
2026-05-27T17:26:00Z INFO Banned due to scan (security.scan-ban) listenerId = "https", localPort = 443, remoteIp = 101.47.8.187, remotePort = 58518, remoteIp = 101.47.8.187, path = "/public/index.php"
The documentation states that this action should be immediately in effect
Auto-banning | Stalwart states:
If an IP address attempts to scan these ports and the number of attempts exceeds a pre-configured threshold, Stalwart will automatically block the offending IP address. This immediate response prevents attackers from continuing their scan and reduces the risk of further exploitation.
This probably happened because the attacker connected over HTTP with Keep-Alive enabled and reused the same connection for the scans. This gap has now been fixed. The fix will be included in v0.16.7.
