Migrated from v0.15.5 → v0.16.14 in Docker (recovery mode + stalwart-cli apply export.json; apply succeeded, 0 failed — domains, accounts, DKIM, certs all present via CLI). Server is fully functional: JMAP over HTTPS returns 200, IMAP auth works, 12M+ emails indexed in Elasticsearch.
However /admin and /account return 404. This is NOT the usual egress-block cause: the container CAN download the WebUI bundle. From inside the container, curl -sSL https://github.com/stalwartlabs/webui/releases/latest/download/webui.zip returns HTTP 200, 552637 bytes, and objects.githubusercontent.com is reachable. Despite the successful download, the bundle is never unpacked or installed.
Question: What triggers the actual unpack/install of the WebUI Application bundle? Why would the download succeed (200) yet no resource.application-unpacked occur, and why is a manually-staged bundle at the configured unpackDirectory not served?
On first start after migration, the server fetches the WebUI bundle from GitHub, unpacks it, and serves the admin console at /admin and the account manager at /account (returning the SPA rather than 404). Per the docs, a successful fetch should emit a resource.application-unpacked event.
Both /admin and /account return 404 Not Found. The bundle download itself succeeds (verified: HTTP 200, 552637 bytes from inside the container), but no resource.application-unpacked event appears and no bundle is unpacked (find /tmp inside the container shows no WebUI files). Setting unpackDirectory=/var/lib/stalwart/webui and manually unzipping the valid bundle there (index.html present, owned by uid 2000) is also not served — still 404 after restart. Triggering create Action/UpdateApps via stalwart-cli returns a created Action id but produces no unpack and no change.
- Migrate a v0.15.5 Docker/RocksDB deployment to v0.16.14 via recovery mode + stalwart-cli apply export.json (completes 0 failed).
- Start the server normally with config.json pointing DataStore at /var/lib/stalwart.
- Request /admin or /account over the HTTP listener.
- Observe 404 Not Found, despite the container being able to download webui.zip from GitHub (curl returns 200) and despite no resource.application-unpacked event being logged.
“No resource/application/webui/unpack log lines are emitted at all, even at trace level.”
Elasticsearch
Ruling out the common causes:
- Egress is NOT blocked: from inside the container, curl of the webui.zip URL returns HTTP 200 (552637 bytes), and both github.com and objects.githubusercontent.com are reachable on 443.
- config.json DataStore path is correct (/var/lib/stalwart, patched from the old /opt/stalwart during migration — verified no /opt/stalwart references remain).
- The Application record looks correct: enabled=true, resourceUrl=https://github.com/stalwartlabs/webui/releases/latest/download/webui.zip, urlPrefix=/admin + /account, autoUpdateFrequency=30d.
Workarounds attempted, none served the UI:
- Set unpackDirectory=/var/lib/stalwart/webui and manually unzipped the downloaded bundle there (correct structure — index.html, assets/, favicon.svg at top level; chowned to uid 2000). Verified present inside the container. Still 404 after restart.
- Triggered
stalwart-cli create Action/UpdateApps— returns a created Action id, HTTP 200, but no unpack occurs and no resource.application-unpacked event is logged. - Multiple full container restarts — no change.
Environment: Docker image stalwartlabs/stalwart:v0.16.14, Ubuntu 24.04 host, RocksDB data store (~59 GB), filesystem blob store on ZFS, Elasticsearch FTS, behind a Caddy reverse proxy. JMAP over HTTPS through Caddy works correctly (returns 200) and IMAP authentication works, so the server itself is healthy — the issue is isolated to the WebUI Application bundle not being unpacked/served.
Container runs as uid 2000; nofile ulimit raised to 1048576.
