the license loading from file in my cluster setup didn’t work, so I reverted to secret values in the WebUI. It loaded the and validated the enterprise license, but when I wanted to update/add/change the default branding logo, the password manager auto filled the secret fields, so I can’t update the branding URL without breaking the license secret values.
Have the license fields separate license screen/page, from the default logo/branding
merging the two have auto fill break the license secrets when attempting to update/setup the branding logo.
- add license secrets via “Value” in the Enterprise setting tab
- validate/restart the stalwart web ui etc.
- go back to Enterprise tab, fill in the Default Branding logo URL,
- have password manager/etc. fill something in the secrets value fields.
- attempt to clean/reset them…
- saving this page now with branding URL invalidates enterprise licensing
2026-06-24T00:18:41Z WARN Configuration build warning (registry.build-warning) source = “Enterprise”, id = 20080258862541, key = (null), reason = “Failed to renew license: Failed to fetch https://license.stalw.art/api/license/ecs-ops.co.za: Code: Unauthorized, Details: Unauthorized”
2026-06-24T00:21:52Z WARN Configuration build warning (registry.build-warning) source = “Enterprise”, id = 20080258862541, key = (null), reason = “Failed to renew license: Failed to fetch https://license.stalw.art/api/license/envisagecloud.co.za: Code: Unauthorized, Details: Unauthorized”
2026-06-24T00:24:36Z INFO Server licensing event (server.licensing) details = “Stalwart Enterprise Edition license key is valid”, domain = “envisagecloud.co.za”, total = 25, validFrom = “2026-05-19T22:24:02Z”, validTo = “2027-06-28T22:24:02Z”
2026-06-24T00:59:16Z WARN Configuration build warning (registry.build-warning) source = “Enterprise”, id = 20080258862541, key = (null), reason = “Failed to renew license: Failed to fetch https://license.stalw.art/api/license/envisagecloud.co.za: Code: Unauthorized, Details: Unauthorized”
2026-06-24T08:32:25Z WARN Configuration build warning (registry.build-warning) source = “Enterprise”, id = 20080258862541, key = (null), reason = “Failed to renew license: Failed to fetch https://license.stalw.art/api/license/envisagecloud.co.za: Code: Unauthorized, Details: Unauthorized”
2026-06-24T09:05:13Z INFO Server licensing event (server.licensing) details = “Stalwart Enterprise Edition license key is valid”, domain = “envisagecloud.co.za”, total = 25, validFrom = “2026-05-19T22:24:02Z”, validTo = “2027-06-28T22:24:02Z”
FoundationDB
