Zone not found or not accessible on DNS update
I am using the automatic DNS update for OVH, but when Stalwart tries to update the DNS records, I get error messages: Zone not found or not accessible. How can I solve this?
The earlier doc_search result showed this content was in dns-server.md around line 1339-1352. Let me read that section directly.
Let me look for the OVH-specific section in the dns-server reference doc:
The file is very large (5432 lines); let me search for the OVH section specifically.
The file is very large (5432 lines). Let me search the full file differently.
The file seems to be very large (5432 lines). Let me search in it differently.
That message comes from the OVH zone lookup (a GET on /domain/zone/), and it collapses any underlying 401/403/404 into the same “not found or not accessible” string, so the real cause is upstream, not Stalwart. In order of likelihood: the consumer key isn’t scoped to /domain/zone/* (or was never validated), so OVH returns 403; the wrong region endpoint is configured (ovh-eu vs ovh-ca etc.) so the zone isn’t visible under that API host; or the domain is only registered at OVH but its DNS isn’t hosted as an OVH zone (external nameservers), which gives a 404.
I’d regenerate the OVH token granting GET/POST/PUT/DELETE on /domain/zone/*, confirm the region matches your account, and check the domain is actually using OVH’s nameservers. That’s the same credential setup I described in your other thread, and fixing the scope there should clear this.
