0.16.5 DNS RFC2136 TSIG update fails with "TSIG key required, but packet does not contain key. Sending REFUSED"
Topic
Running the new 0.16.5 but powerdns only says TSIG key required, but packet does not contain key. Sending REFUSED
Validating with nsupdate
nsupdate -v -d -y hmac-sha256:stalwart:key <<EOF
server dns-ip 53
zone domain.io
update add tsig-test.domain.io 60 TXT "tsig-works"
send
EOF
Record is set and I can query it, meaning key is active and authorized for the zone
Running config
Type: RFC2136 (TSIG)
Connection
  Hostname: dns-ip
  Port:     53
  Protocol: UDP
Authentication
  TSIG Algorithm: HMAC-SHA256
  Key Name:       stalwart
  Key Secret:
    Type: Secret value
    Secret
      Secret: *****
Timing
  Timeout:                   30 s
  TTL:                       5 m
  Polling Interval:          15 s
  Propagation Timeout:       1 m
  Initial Propagation Delay: <none>
Details
  Description: PDNS
  Tenant:      <none>
Tried a secret file just in case but no luck. Running dnsdist in front of the PDNS servers but since the nsupdate works from any client (other servers, laptop, etc) I dont think it´s a config related to dnsdist or powerdns.
Anything more I can do to debug?
TSIG working/sending keys
TSIG arrives without key
This was a regression and it has been fixed.
Hi, I’m evaluating the enterprise version and facing the same issue. Can you tell in which release this error will be fixed? I’ve installed the latest version which seems to be 0.16.5
I can confirm that RFC2136 dynamic DNS updates are working now :slight_smile:
