I have a DKIM signature configured for a domain. In the DkimSignature object, some headers to be signed were added manually under “Signed Headers”, e.g. CC.
When I now enable automatic DNS management for this domain, after the task runs (or is manually triggered) a new DkimSignature object gets created. However, this new object does not include the headers previously added to “Signed Headers”. Thus, they are no longer signed after the key rotates.
The new DkimSignature object uses the same “Signed Headers” as the one it replaces, they get carried over.
The new DkimSignature object uses only the default “Signed Headers”.
Create a DkimSignature object
Add a non-default header to “Signed Headers”
Enable automatic DKIM management
Wait or force DKIM key rotation
Observe new DkimSignature object does not include non-default header set in step 2.
v1.x
This looks like a real gap in v1.0, not a configuration mistake on your side.
When the automatic DKIM management task creates a signature, it builds the new DkimSignature from scratch. It sets only the stage, domain, selector, private key and (on Enterprise) the tenant, then fills everything else with ..Default::default(). I found no code that reads the existing signature for the domain and copies its Signed Headers onto the replacement. The task only looks at the existing signatures to decide which algorithms still need a new key and which rotation stage each one is in. So any non-default signed headers, such as your CC, are lost when the replacement key is created. This matches what you observed.
I only read the creation path in crates/services/src/task_manager/tasks/dkim.rs. I didn’t find a setting that changes this, and I can’t promise there isn’t one elsewhere. As far as I can tell, you’d have to re-add the headers to each new DkimSignature object after each rotation. You can do that in the WebUI or with stalwart-cli. A permanent fix would need a code change, so a staff member will need to confirm and follow up here.
Fixed for the next weekly Stalwart release. When automatic management rotates a key, the new DkimSignature now starts from the one it replaces: signed headers, canonicalization, expiry, AUID, the report flag and the third-party settings all carry over, and only the selector, key and rotation dates are new.
The new key is copied from the current active one, so after upgrading, check that the active signature for each algorithm still has Cc in “Signed Headers”. If a rotation already reset it, add it back once and every key after that will keep it. Until the release is out, re-adding the extra headers to the new signature after each rotation is the workaround.
