CalendarEvent/get omits explicitly requested isOrigin
CalendarEvent/get does not return the isOrigin property when the client explicitly includes isOrigin in the properties argument.
The property is returned when fetching all properties, but is omitted when using a restricted property list.
isOrigin is a server-set property defined by JMAP Calendars draft-26.
Source inspection suggests a property-projection bug in crates/jmap/src/calendar_event/get.rs.
When processing the requested property list, the IsOrigin branch sets:
return_is_origin = true;
but, unlike the other calculated JMAP properties, does not add the property to jmap_properties.
The value is therefore calculated later, but never inserted into the response object.
A request such as:
  "accountId": "...",
  "ids": ["..."],
  "properties": [
    "id",
    "organizerCalendarAddress",
    "isOrigin"
should return isOrigin for each returned event.
For an event whose organizerCalendarAddress is null, the specification defines isOrigin as true.
When isOrigin is explicitly requested in a restricted properties list, Stalwart omits the property from the returned object.
Fetching the same event without supplying the properties argument takes a different code path and includes isOrigin.
Clients which deserialize an absent boolean as false may consequently interpret the event as isOrigin: false, even when the event’s organizer state implies otherwise.
  1. Create or identify any CalendarEvent.
  2. Fetch it with a restricted property list containing isOrigin, for example:
  "CalendarEvent/get",
    "accountId": "...",
    "ids": ["..."],
    "properties": [
      "id",
      "isOrigin"
  "0"
  1. Inspect the raw JMAP response.
  2. Observe that isOrigin is absent despite having been explicitly requested.
  3. Fetch the same event again without supplying the properties argument.
  4. Observe that the full-property response includes isOrigin.
No relevant error is logged. The request succeeds normally; the requested property is simply omitted from the response.
This confirms the reported bug exactly. Given this is a solid technical bug report with source-level confirmation, I’ll acknowledge it clearly and concisely, matching the fallback style expected for confirmed source issues (not asking for more info, since ripdog already did the legwork).
Your source inspection is correct. In crates/jmap/src/calendar_event/get.rs, the restricted-property branch for JSCalendarProperty::IsOrigin only sets return_is_origin = true but never pushes JSCalendarProperty::IsOrigin into jmap_properties, unlike the return_all_properties path (which explicitly includes it in the property vector) and unlike the other computed properties (UtcStart/UtcEnd, which push the property alongside setting their flag). That means when a restricted list is used, isOrigin is computed later but has no corresponding entry to attach the value to in the response, so it’s silently dropped.
This is a genuine bug matching what you described, thanks for the detailed writeup and source pointer. A human maintainer will follow up on the fix.
