Calendar/get omits some Calendar properties when properties is omitted or null.
For example, defaultAlertsWithTime and defaultAlertsWithoutTime are only returned when explicitly requested.
The Calendars specification defines Calendar/get as:
“This is a standard “/get” method as described in Section 5.1 of [RFC8620].”
RFC 8620 §5.1 says:
“If null, all properties of the object are returned.”
With no properties argument, all Calendar properties should be returned, including defaultAlertsWithTime and defaultAlertsWithoutTime.
A request such as:
["Calendar/get", {
"accountId": "account1",
"ids": ["calendar1"]
}, "0"]
omits the default alert properties.
Explicitly requesting them:
["Calendar/get", {
"ids": ["calendar1"],
"properties": [
"id",
"defaultAlertsWithTime",
"defaultAlertsWithoutTime"
}, "0"]
returns the configured value correctly, e.g.:
"defaultAlertsWithTime": {
"alert1": {
"@type": "Alert",
"action": "display",
"trigger": {
"@type": "OffsetTrigger",
"relativeTo": "start",
"offset": "-PT10M"
- Configure a Calendar with a default alert.
- Call
Calendar/getwithoutproperties; observe that the default alert properties are absent. - Repeat while explicitly requesting
defaultAlertsWithTimeanddefaultAlertsWithoutTime; observe that they are returned.
No error is logged; the request succeeds normally. The issue is limited to the returned property set.
Built from source
