CalendarEvent/get returns baseEventId for a normal, non-synthetic event
CalendarEvent/get returns baseEventId for a normal, non-synthetic event, with the value equal to the event’s own id.
baseEventId is intended to identify the underlying base event when the returned object represents a synthetic expanded recurrence instance.
For a normal CalendarEvent, baseEventId should be null.
For a synthetic recurrence instance, baseEventId should contain the id of the underlying real CalendarEvent.
For a normal event, Stalwart returns:
  "id": "<event-id>",
  "baseEventId": "<event-id>"
The event therefore identifies itself as its own base event.
  1. Create a normal, non-recurring CalendarEvent.
  2. Fetch it with:
  "properties": ["id", "baseEventId"]
  1. Observe that baseEventId is returned with the same value as id.
No error is reported.
Built from source
Looking at the source, this does appear to be a genuine bug. In get.rs, the BaseEventId property is populated unconditionally from the returned event’s own id, regardless of whether the event is a real event or a synthetic expanded recurrence instance:
JSCalendarProperty::BaseEventId => {
    result.insert_unchecked(
        JSCalendarProperty::BaseEventId,
        Value::Element(JSCalendarValue::Id(id.document_id().into())),
There’s no check distinguishing a synthetic instance from the base event here, so every returned event (synthetic or not) gets its own id echoed back as baseEventId instead of null for normal events. This matches what you’re seeing. A human maintainer will need to confirm and patch this, since it’s a code-level fix rather than a configuration or docs issue.
Fixed in v0.16.22 (yet to be released).
