Calendar defaults appear to be copied into an event’s stored iCalendar when an event with useDefaultAlerts: true is written.
Changing defaultAlertsWithTime/defaultAlertsWithoutTime later updates the calendar preferences, but does not update existing events, so their CalDAV VALARMs can become stale.
Events with useDefaultAlerts: true should reflect the calendar’s current default alerts.
An event can continue exposing the old materialized default through CalDAV after the calendar default has changed.
- Set a calendar default alert for 10 minutes before.
- Create an event with
useDefaultAlerts: true. - Confirm CalDAV exposes a 10-minute
VALARM. - Change the calendar default to 20 minutes before.
- Fetch the event again through CalDAV.
- Observe that it still exposes the old 10-minute alarm.
N/A
Built from source
