Two unprivileged local accounts with reciprocal user Sieve redirect rules (A forwards to B, B forwards to A — a typical vacation-forwarding setup created via a webmail rule builder) create an infinite internal mail loop. No existing loop-control mechanism catches it: the Sieve engine’s redirect loop avoidance and MAXREDIRECTS operate per script execution, so each hop is a single legal redirect, and the cycle only exists across the two accounts. RFC 5228 §4.2 requires loop control measures; per-script control exists, cross-account control does not.
The consequence is unbounded database growth: every loop iteration writes the full message blob again (twice, due to “keep”), and since v0.16.10 each iteration additionally re-triggers RocksDB blob garbage collection, whose compactions rewrite ~270 MB blob files continuously — the loop and the GC feed each other. In our incident the store grew until the disk was full. Effectively an unprivileged DoS: two ordinary user accounts can take down the entire server. On our HDD-backed storage the episode ended in RocksDB corruption after an unclean stop and required a restore from backup.
The server detects that a message is circulating between local accounts via redirect and terminates the loop after a small number of hops, delivering locally instead of redirecting again — analogous to Exchange’s auto-forward limit. The existing duplicate (RFC 7352) tracking infrastructure could serve this: if the same Message-ID re-enters an account via redirect within a short window, deliver locally.
The message circulates indefinitely; the database grows without bound (~400 writes/s sustained, ~70 MB flushes every ~4 s on an otherwise idle server) until the disk is full and the server fails. “keep” additionally deposits a copy in both mailboxes on every iteration. Client-side mitigations (guard headers in generated scripts) cannot be enforced, since any ManageSieve/JMAP client or hand-written script bypasses them.
Create two local accounts A and B, no special permissions.
Upload this user Sieve script to A (and the mirror image to B, redirecting to A):
if header :contains “From” “@” {
redirect “[email protected]”;
keep;
Send one external email (ideally with a large attachment) to either account.
Observe the message looping between A and B; database size and write load grow unbounded until the disk is full.
Loop signature — identical ~70 MB memtable flushes every ~4 s on an otherwise idle server (sequence numbers grew from 144,001,813 to 144,091,184 in ~3.5 min, ~400 writes/s, no client traffic):
2026/07/03-23:58:22.968203 EVENT_LOG_v1 {"job": 40, "event": "flush_started", "num_memtables": 1, "total_num_input_entries": 14, "num_deletes": 0, "total_data_size": 70504793, "flush_reason": "Write Buffer Full"}
2026/07/03-23:59:17.282108 EVENT_LOG_v1 {"job": 59, "event": "flush_started", "num_memtables": 1, "total_num_input_entries": 14, "num_deletes": 0, "total_data_size": 70790381, "flush_reason": "Write Buffer Full"}
14 entries producing a ~70 MB write buffer means these are almost pure message blobs (large mails/attachments), the same handful of messages re-written on every loop iteration.
Each batch of L0 flushes crosses the threshold and triggers a compaction that rewrites ~270 MB blob files — this is the RocksDB blob GC introduced in v0.16.10, so the loop and the GC continuously feed each other:
2026/07/03-23:59:13.237058 [t] Level summary: files[4 0 0 0 0 2 19] max score 1.00, estimated pending compaction bytes 67265454
2026/07/03-23:59:13.237213 EVENT_LOG_v1 {"job": 58, "event": "compaction_started", "cf_name": "t", "compaction_reason": "LevelL0FilesNum", "files_L0": [25590, 25587, 25581, 25574], "score": 1}
2026/07/03-23:59:13.993786 EVENT_LOG_v1 {"job": 58, "event": "blob_file_creation", "file_number": 25592, "total_blob_count": 54, "total_blob_bytes": 271340696, "status": "OK"}
2026/07/03-23:59:14.775375 EVENT_LOG_v1 {"job": 58, "event": "blob_file_creation", "file_number": 25594, "total_blob_count": 54, "total_blob_bytes": 271465528, "status": "OK"}
For scale, blob files are ~270 MB each and were being produced roughly one per ~0.8 s during the sustained loop (file numbers climbed 25318 → 25596+ in minutes), i.e. hundreds of MB/s of blob rewrites driven entirely by the two-message loop.
Single node, LXC container on ZFS (HDD pool at the time of the incident — which made the sustained compaction pressure worse, but the unbounded growth itself is storage-independent). The rules were created via a JMAP webmail client’s visual rule builder; the generated catch-all condition (From contains “@”) matches every message, including forwarded ones. The issue is client-independent: any ManageSieve/JMAP client or hand-written script produces the same result.
Happy to provide full RocksDB LOG files, the second account’s script, or test a patched build against the reproduction.
