using Stalwart lastest release
Created a system Sieve script in WebUI (Settings > Sieve > System Scripts):
require [“editheader”];
deleteheader :index 1 “User-Agent”;
deleteheader :index 1 “X-Originating-IP”;
Bound it to DATA Stage (Settings > MTA > Session > DATA Stage > Run Script):
{“else”: “‘remove-privacy-headers’”}
editheader extension is enabled.
Result:
- Log says: "Warning Sieve script not found "
- Script is visible in WebUI list
- User-Agent header remains in delivered message
- Tried recreating with different name, same result
- Tried :index 1, :matches “*”, unconditional deleteheader — none work
Looks like the script exists in WebUI but isn’t loaded at runtime. systemctl restart stalwart doesn’t make any difference. Either a cache/sync bug or the script reference format is wrong.
should apply script
Built from source
