When editing a user to for eq. add/remove group membership, the save keep failing with the “Domain” field having the error: This Field is required
that is after I’ve already selected a domain from the check list.
Save is succesfull
Domain*
Identifier for the domain this account belongs to. This is used to determine the email address of the account, which is formed as name@domain.
hevis.co.za
This field is required.
configure/load keys via a AI CLI tooling
try to understnd/edit via the WebUI
tr to “Save”
FoundationDB
Let me look into this WebUI validation issue with the Domain field.
I found the key validation logic. The validateRequired function checks if required objectId type fields are empty. Now let me look at what exactly happens with the domainId field during edits and whether there’s a known bug around this.
I haven’t been able to reproduce this on an account created in the WebUI, so I suspect it’s specific to how the principal was stored when it was created by your CLI tooling: if the name or domain ended up in a shape the edit form’s domain selector doesn’t bind to, the required check can fire even though a value looks selected.
Does it also happen for a user you create entirely in the WebUI, or only for the CLI-created one? And can you paste the stored principal (stalwart-cli account display , or the JSON you used to create it), in particular whether the account name already includes the @domain suffix and how the domain is stored? With that I can match it to the form’s expected shape and fix whichever side is wrong.
Hmmm… yeah, looks like it’s either fixed in the last version, or there were some other caching thing that might’ve caused this. as today I can’t seem to trigger it as reliably as I could when I logged this ticket.
