"Failed to read RSA DER"
I am trying to generate a new RSA key pair. I have used the WebUI to do so, but I cannot see the public key listed in the output when I click on show DNS records. I’ve also tried to use the stalwart-cli to get the public key, but that fails with this error; Request failed: Failed to read RSA DER)
I ought to be able to view the key so I can put it in DNS.
Public key is unavailable.
  1. Generate RSA key via the UI
  2. Go to domains to see the listed key
DEBUG Management error (manage.error) listenerId = "https", localPort = 443, remoteIp = fe80::f816:3eff:fe4d:e655, remotePort = 46022, details = "Failed to read RSA DER", reason = "Cryptography layer error:
  VersionNotSupported"
2026-05-14T20:06:59Z TRACE HTTP response body (http.response-body) listenerId = "https", localPort = 443, remoteIp = fe80::f816:3eff:fe4d:e655, remotePort = 46022, contents = "{"error":"other","details":"Failed to read RSA DER","reason":"Cryptography layer
  error:
   VersionNotSupported"}", code = 200, size = 109
v0.15.x
ed25519 key works fine, other keys are able to be returned.
The key issue is clear from looking at the source code. The "Failed to read RSA DER" / "VersionNotSupported" error occurs in generate_dkim_public_key when it tries to call Document::from_pkcs1_der() on the public key produced by rsa_key_parse. The error VersionNotSupported is a well-known error from the pkcs8 crate when the DER data is in PKCS#8 format rather than PKCS#1 format (or vice versa), which can happen when the private key stored in the database was generated with a format mismatch.
The most likely cause is a format mismatch in the stored RSA private key. The WebUI-generated RSA key is stored as a PEM wrapped PKCS#1 key (-----BEGIN RSA PRIVATE KEY-----), but the public key extraction path (Document::from_pkcs1_der) will fail with VersionNotSupported if the underlying DER is actually PKCS#8 (-----BEGIN PRIVATE KEY-----), or the stored PEM was corrupted/truncated during saving.
Here’s what to check and try:
  1. Verify the stored key format. Retrieve the raw private key value from the DKIM signature object (via the WebUI or CLI). It should start with -----BEGIN RSA PRIVATE KEY----- (PKCS#1). If it starts with -----BEGIN PRIVATE KEY----- (PKCS#8), the public-key extraction path in the current code expects PKCS#1 DER specifically for the from_pkcs1_der step and that mismatch causes VersionNotSupported.
  2. Delete and regenerate the RSA key pair via the WebUI. The generate_dkim_private_key function in source explicitly generates with the "RSA PRIVATE KEY" PEM header (PKCS#1), so a freshly generated key should work. If the key you’re hitting was created by an older version, the format may differ.
  3. As a workaround to get the public key now, you can extract it locally. Export/copy the raw PEM private key from the stored object, save it as private.key, and run:
    openssl rsa -in private.key -pubout -outform der 2>/dev/null | openssl base64 -A
    Then publish the DNS TXT record manually:
    v=DKIM1; k=rsa; p=<base64-output>
This is consistent with your observation that Ed25519 works fine – the Ed25519 code path uses a different PEM parser (simple_pem_parse) and is not affected by PKCS version.
Reference: DKIM Signing documentation
The key is available in the UI, will that suffice?
Is the format of the key
v0.15 reads the stored RSA private key DER as PKCS#1 only; if the key was stored in PKCS#8 form (header -----BEGIN PRIVATE KEY-----) the parse fails with VersionNotSupported. We unified that in 0.16 (a rsa_key_parse that tries PKCS#1 then PKCS#8), so the upgrade fixes it.
If you need the public key on 0.15 today, you can try using openssl.
Yes, I solved this by using openssl to create a PKCS#1 key.
