Affected: v0.15.4 through v0.16.23, main, v1.0.0.
The HTTPS listener never closes idle HTTP/1.1 connections. Behind a load balancer or NAT that silently drops idle flows (AWS NLB does so after 350 s), the client’s later FIN/RST never reaches Stalwart, so the socket stays ESTABLISHED forever and keeps its maxConnections slot. Once the limit is reached, all new HTTPS connections are refused.
Cause: the http1 builder has no timer:
so hyper discards its default 30 s header_read_timeout, which also bounds keep-alive idle time:
and accepted sockets never get SO_KEEPALIVE
Fix: add .timer(hyper_util::rt::TokioTimer::new()) to the builder, and set TCP keepalive in SocketOpts::apply via socket2::SockRef::set_tcp_keepalive.
An idle HTTP connection is closed after a bounded time, like hyper’s default 30 s header read timeout or the idle timeouts on Stalwart’s other listeners, or a dead peer is detected with TCP keepalive. Its maxConnections slot is then released.
Idle HTTP connections are never closed by the server. If the peer disappears without its FIN/RST reaching Stalwart, the socket stays ESTABLISHED. These sockets accumulate until the listener’s maxConnections is reached and every new connection hits limit.concurrent-connection.
- Run Stalwart with the default HTTPS listener on 443.
- Open a connection and leave it idle:
openssl s_client -connect <host>:443 -quiet, then send one request or nothing. - Inside the Stalwart host or container, run
ss -tni state established '( sport = :443 )'. The connection is still ESTABLISHED after several minutes; it was never closed after 30 s. - To reproduce the leak: put Stalwart behind a load balancer or NAT with an idle timeout (e.g. an AWS NLB at the 350 s default), let clients keep connections idle past that timeout before closing them, and watch the ESTABLISHED count on :443 grow without bound.
2026-09-25T00:21:06Z WARN Concurrent connection limit reached (limit.concurrent-connection) listenerId = “https”, localPort = 443, remoteIp = 62.###.##.###, remotePort = 58818, limit = 8192
OIDC
