JMAP "fetch failed"
Hello all,
Trying to use a JMAP client to my new installation. I tried Parula (which works with IMAP, but not with JAMP), Boogie Mail (IOS, which gives me a fetch failed), Bulwark webmail client. They all give me the “fetch failed” error.
While trying to troubleshoot like below, I get an empty http response:
curl -sv https://myserver.domain.tld/.well-known/jmap
Host myserver.domain.tld:443 was resolved.
IPv6: (none)
IPv4: 10.135.101.53
Trying 10.135.101.53:443…
ALPN: curl offers h2,http/1.1
TLSv1.3 (OUT), TLS handshake, Client hello (1):
SSL Trust Anchors:
CAfile: /etc/ssl/certs/ca-certificates.crt
TLSv1.3 (IN), TLS handshake, Server hello (2):
TLSv1.3 (IN), TLS change cipher, Change cipher spec (1):
TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
TLSv1.3 (IN), TLS handshake, Certificate (11):
TLSv1.3 (IN), TLS handshake, CERT verify (15):
TLSv1.3 (IN), TLS handshake, Finished (20):
TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
TLSv1.3 (OUT), TLS handshake, Finished (20):
SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384 / X25519MLKEM768 / id-ecPublicKey
ALPN: server did not agree on a protocol. Uses default.
Server certificate:
subject: CN=rcgen self signed cert
start date: Jan 1 00:00:00 1975 GMT
expire date: Jan 1 00:00:00 4096 GMT
issuer: CN=rcgen self signed cert
Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA256
subjectAltName does not match hostname myserver.domain.tld
SSL: no alternative certificate subject name matches target hostname ‘myserver.domain.tld’
closing connection #0
The certificate is self-signed, but still, shouldn’t I get some json formated output ? Or what shall I expect from this command ?
Thanks a lot
The empty response you’re seeing from curl isn’t actually a JMAP problem, it’s TLS failing before curl ever gets an HTTP response. The log shows the connection was aborted because the certificate presented doesn’t match your hostname (“subjectAlternativeName does not match hostname”). That’s a client-side abort, not a server bug: curl refuses to read the body when the cert doesn’t validate.
Your server is falling back to its built-in self-signed placeholder certificate (CN=rcgen self signed cert), which means no valid Certificate is bound to that hostname yet. This happens if:
  • No Domain object exists for myserver.domain.tld with a working certificateManagement set (Manual or Automatic/ACME), or
  • The domain has automatic (ACME/Let’s Encrypt) certificate management but hasn’t successfully issued a certificate yet, or
  • No defaultCertificateId is set on SystemSettings and the listener has no matching Certificate for that SNI.
You have two options:
  1. Test JMAP client behavior ignoring the cert with curl -sv -k https://myserver.domain.tld/.well-known/jmap — if that returns proper JSON, it confirms the JMAP endpoint itself is fine and the only problem is the invalid cert.
  2. Fix TLS: either upload a real Certificate object for that hostname or configure Domain certificateManagement to use an AcmeProvider (Let’s Encrypt) so a valid certificate is issued automatically.
Once the certificate matches the hostname, JMAP clients like Parula/Boogie/Bulwark should stop failing with “fetch failed”, since that error is typically the client’s TLS handshake aborting exactly as curl’s did.
See: TLS certificates | Stalwart and Overview | Stalwart
ok, I’ve created a custom certificate which is trusted by the client. Here’s the response, which is still empty, but this time there are no errors in the response header.
###begin###
  • Host myserver.domain.tld:443 was resolved.
  • IPv6: (none)
  • IPv4: 10.135.101.53
  • Trying 10.135.101.53:443…
  • ALPN: curl offers h2,http/1.1
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • SSL Trust Anchors:
  • CAfile: /etc/ssl/certs/ca-certificates.crt
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.3 (IN), TLS change cipher, Change cipher spec (1):
  • TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384 / X25519MLKEM768 / RSASSA-PSS
  • ALPN: server did not agree on a protocol. Uses default.
  • Server certificate:
  • subject: CN=MYSERVer.domain.tld; C=RO; ST=County; L=MyCity; O=MyneTWOrk; OU=IT
  • start date: Jul 4 19:37:21 2026 GMT
  • expire date: Jul 4 19:37:21 2027 GMT
  • issuer: C=RO; ST=Ilfov; L=București; O=MyneTWOrk; CN=CA_sign.domain.tld
  • Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
  • Certificate level 1: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
  • subjectAltName: “myserver.domain.tld” matches cert’s “MYSERVer.domain.tld”
  • SSL certificate verified via OpenSSL.
  • Established connection to myserver.domain.tld (10.135.101.53 port 443) from 10.134.98.5 port 34474
  • using HTTP/1.x
GET /.well-known/jmap HTTP/1.1
Host: myserver.domain.tld
User-Agent: curl/8.17.0
Accept: /
  • Request completely sent off
  • TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
    < HTTP/1.1 307 Temporary Redirect
    < cache-control: no-cache
    < location: /jmap/session
    < content-length: 0
    < date: Tue, 07 Jul 2026 12:41:37 GMT
  • Connection #0 to host myserver.domain.tld:443 left intact
##### end ###
This is a redirect to /jmap/session. Add --location to your curl parameters to follow redirects.
I did this: curl -X POST https ://myserver.domain.tld/.well-known/jmap
and the response was:
{“type”:“about:blank”,“status”:404,“title”:“Not Found”,“detail”:“The requested resource does not exist on this server.”}
Also, after some searching I released that this is being reported by numerous people, but no solution yet.
