I am trying to get the stalwart-cli and plans to work with Nix, but after 4 days, I am struggling.
There are commands in the docs that don’t appear to work, such as;
stalwart-cli query Certificate --where text=domain --url https://domain --user admin
Password:
error: jmap error: unsupportedFilter: Filter on property text is not supported or invalid
It fails with or without the quoted domain.
Filters in general are giving me grief as gettings errors that ‘text’ is not a supported filter, when it is stated in the docs, as the only one supported.
I have a number of other questions, but they will have to wait.
Stalwart 0.16.9, cli 1.0.8
Welp, I’m not sure if the response you’re receiving is a bug or not. I do know the docs say; “To list which filters an object supports, run describe <object>. The Filters: section lists each accepted key, its kind, and a label.” In the case of Certificate it is;
Certificate
Defines a TLS certificate and its associated private key.
Fields:
certificate object<PublicText> mutable
TLS certificate in PEM format
issuer string<string> server-set
Certificate issuer
notValidAfter datetime server-set
Expiration date of the certificate
notValidBefore datetime server-set
Issuance date of the certificate
privateKey object<SecretText> mutable
Private key in PEM format
subjectAlternativeNames set<string<string>> server-set
Subject Alternative Names (SAN) for the certificate
Filters:
text text Text
