Stalwart runs IMAP STORE in a background task. A following pipelined EXPUNGE can run before the \Deleted flag is committed.
The message is not expunged and later reappears in the client.
Seen with Geary, which pipelines UID STORE followed by UID EXPUNGE when deleting messages.
STORE uses a background task, while EXPUNGE runs inline. The fix awaits STORE inline so later commands see the completed update.
Fix and test:
GH: @prasannavl if you’re open to accepting PRs as I have a few more some of which I’ve already created issues for here. Thanks!
Pipelined commands should execute in the order received. EXPUNGE should see the flag change made by STORE.
EXPUNGE can finish before STORE. It finds no deleted messages, then STORE applies the \Deleted flag afterward.
- Select a mailbox containing one message.
- Send STORE and EXPUNGE in one pipelined batch:
A1 STORE 1 +FLAGS.SILENT (\Deleted)
A2 EXPUNGE
- Select the mailbox again.
- The message may still be present with \Deleted set.
A1 OK STORE completed
A2 OK EXPUNGE completed
No EXPUNGE response is returned for the message.
LDAP
