Sieve: include for global/system scripts fails when the target script name has uppercase characters
When trying to include a system sieve script that has uppercase letters in its name from another system sieve script, stalwart can’t find it.
Included system scripts with uppercase letters are found
script is not found, error log suggesting it tries to find a script with a lowercase name
  1. Create a Sieve System Script named “UPPER”
  2. Create a second System Script named “lower”
  3. from a third System script try to include “UPPER”, which will fail with a log message that the script “upper” is not found, same with a include for “lower” will work
This appears to be a genuine bug in the sieve include logic, not a configuration issue. Looking at the server source: system scripts are stored in memory keyed by their original name as saved (untrusted_scripts.insert(script.object.name, ...) in mailstore/scripts.rs), but when a script is included via Event::IncludeScript for a Global script, the lookup calls get_untrusted_sieve_script(&name_.to_lowercase(), ...) in network/mta.rs, which force-lowercases the name before searching the map.
So any global/system script whose stored name contains uppercase characters will never match on lookup, since the map key retains the original case but the include lookup always searches for the lowercased version. Scripts with all-lowercase names work by coincidence, since the lowercased search key happens to match the stored key.
This is a genuine mismatch between how names are stored and how they’re looked up during include, confirmed in the current source, and matches your reproduction exactly. A staff/dev follow-up will be needed to fix the lookup (or normalize storage) so it’s consistent.
