When I tried to add the Roles “Tenant Administrator” to UserT@TA/com, I get the message:
This item references another item that does not exist.
What am I doing wrong?What more do I need to check?
What would the CLI approach be?
“This item references another item that does not exist” means the role you’re assigning can’t be resolved in that principal’s scope, so it’s a setup/scoping issue rather than the account itself. A couple of things to confirm: is the user’s tenant set before you assign the role, and does the tenant’s own roles/permissions actually include the tenant-admin capability? A tenant can’t grant a permission it doesn’t itself hold, so if the tenant wasn’t granted that, assigning the role to its user fails to resolve.
Also confirm the built-in “Tenant Administrator” role still exists (not renamed or deleted) and is the one you’re selecting. If it keeps failing in the UI, try setting the role via stalwart-cli on the principal to see whether it’s the UI or the underlying reference, and let me know the exact step it fails on.
