Calendar cancellations fail when an attendee URI uses uppercase or mixed-case MAILTO
Stalwart only strips lowercase mailto: before lowercasing the address. “MAILTO: example [at] example [dot] com” therefore becomes “mailto:example [at] example [dot] com” and is used as the SMTP recipient.
Fix and test ready:
Have a few other non breaking fixes as well for better alignment with standard RFCs that we’d like to upstream. Please let me know if this bug fix be acceptable.
GH: @prasannavl if you’re open to accepting PRs. Thanks!
Strip the mailto scheme case-insensitively and send to example [at] example [dot] com
Stalwart sends RCPT TO:mailto example [at] example [dot] com, which our SMTP relay rejects.
- Create an event with ATTENDEE:MAILTO example [at] example [dot] com
- Cancel the event so Stalwart sends an iTIP cancellation.
- Check the outbound SMTP recipient.
RCPT TO:<mailto example [at] example [dot] com>
LDAP
Seen with Gmail app → Z-Push/ActiveSync → Stalwart.
It strips mailto: case-insensitively before lowercasing the address.
