Stalwart calenders iTIP gets rejected
On a stalwart calender:
When sending calender invites from a stalwart calender using either thunderbird or bulwark i get an error mail that says “rejected command ‘DATA’ with code 500 (5.2.3) 'line too long”
If i use a local calendar in thunderbird and configure thunderbird to send mails directly using ahasend then it works fine.
All other mails work fine.
In stalwart routing im using send.ahasend.com as a relay host for all external domains.
Accepted
*Your message could not be delivered to the following recipients:
jesper@xxxx_com (host ‘send_ahasend_com’ rejected command ‘DATA’ with code 500 (5.2.3) ‘line too long’)*
(had to replace . with _ to get the post accepted)
open stalwart calendar in thunderbird or bulwart
send an invite
get the mail back with error
Meilisearch
Maybe it’s:
Stalwart’s default inline logo in every generated iMIP message is emitted with bare LF line endings.
  • imip.rs:105-109 marks pre-encoded logo content as raw base64.
  • lib.rs:432+ defines that base64 string with Rust multiline-string \n, not SMTP-required \r\n.
Because .transfer_encoding("base64") bypasses mail-builder’s normal MIME encoding/line normalization, strict SMTP receivers can treat the entire embedded image as one giant SMTP line and reject DATA with 500 5.2.3 line too long.
Maybe fix:
before emitting the raw base64 logo, convert LF to CRLF—or preferably decode it and let mail-builder base64-encode/wrap it itself.
Thanks.
Btw.Looks like its in v0.16.16 :grinning_face_with_smiling_eyes::+1:(released)
