Calendar emails failed to send through MailPace smtp relay
calendar emails were silently failing because the inline logo part had no filename.. i made a gh issue and fixed it on a branch iMIP/alarm emails: inline logo part has no filename, so strict relays reject calendar invitations · Issue #3203 · stalwartlabs/stalwart · GitHub
The email should be accepted and delivered…
The email is rejected…
  1. Configure Stalwart using MailPace for email sending
  2. Make a calendar invite and add an external recipient
  3. Notice that they didn’t not receive the email
See (closed) gh issue
SQL
MailPace SMTP relay
Thank you for the detailed report and for already linking to the GitHub issue. Based on looking at the server source, this is a known bug in Stalwart’s calendar invite email generation where the inline logo image part is attached without a filename parameter in its Content-Disposition header. Certain SMTP relays (like MailPace) enforce stricter MIME compliance and reject messages with inline attachments missing a filename, causing the calendar invite to be silently dropped.
You’ve already done the hard work: the GitHub issue (#3203) is filed and you have a fix on a branch. The maintainers will review and merge it. In the meantime, the only known workaround is to either:
  • Use a different SMTP relay that is less strict about inline attachment filenames, or
  • Point Stalwart’s outbound mail directly (no relay) if your setup allows it.
There is no configuration knob in Stalwart to add a filename to that part today - it requires the code fix you’ve already authored.
Stalwart’s output is technically RFC-compliant. Per RFC 2183 the filename parameter is optional, and CID-referenced inline images legitimately omit it. MailPace is being stricter than the spec.
