Ban duration of IP blocking seems to be ignored
I set band duration but the actual result differs. i.e. I set block duration to 1 day and yet IPs get blocked for 1 hour.
The block duration should be respected.
Band duration is 1 h instead of 1 day.
  • set block duration to 1 day for Port scanning ban
  • wait for an IP to get blocked due to Port scanning
  • check lsit of blocked IPs
  • see: created at: 30 Jun 2026, 10:03
  • see: expriatio ndate: 30 Jun 2026, 11:03
Let me look into how IP blocking/ban duration is configured and handled in the codebase.
I found something very important. Looking at line 162:
blocked_ip_expiration: security.auth_ban_period.map(|v| v.as_secs()),
The blocked_ip_expiration field is only being populated from auth_ban_period, not from scan_ban_period. Let me verify this is used for all bans.
This has been fixed in v0.16.12 which will be released this week.
