When I enabled DKIMv2, the existing v1 keys were rotated out by DKIM automatic management. At some point the task automatically removed the recods from the zone, as expected, leaving me with the expected four records (2x Ed and 2x RSA).
The old v1 DKIM key set is currently marked DKIM key has been removed from DNS and is pending deletion with a next transition date of Sept 7.
When running task DNS Management for Domain today, the task repopulated the two deleted records back into the DNS zone.
DNS Management tasks should recognize that the records have already been marked as deleted and should not repopulate them.
Records marked deleted are repopulated.
- Perform DKIM rotation.
- Wait for old key records to expire and be removed.
- Perform DNS management task on domain before the next rotation date arrives.
Deleted records repopulated first
2026-08-21T20:58:11Z INFO DNS record created (dns.record-created) hostname = "v1-ed25519-20260529._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=ed25519; h=sha256; p=lTfcZ3zFxjrxnsT06ZMfX0Kd54ENkmvA72yieEHdbm0="]
2026-08-21T20:58:11Z INFO DNS record created (dns.record-created) hostname = "v1-rsa-20260529._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=rsa; h=sha256; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAu2QjsGzb0YJKKnW3gRkybD+Ea0VY4fPfV9dtYuXUN7n2lNc1xlunQB8KhD8AkPW+gq8bGIl5MQOcT6SdhHTCIfLBzRgMIH0SjFZrJJL2iLgKLJ99sIWvaQapPxHZInlQVD2wrxzNrk8WxZBnZ8RH0uIccpBrbIX4MpTNhpXHxw6w/AZUbapfl2RCGIv4wksEaiJJZyRCXv4+s/+TY7U6q8D4zO2rGrDngWsiH00tcgRPFrWZ3mMdxE/kML3MIod9KLlPB3so8E9jMrPAA90L3gsNNFiKYw0nqlRVBO7wJZugemO077gcy3r/0cwX2CjX4nLKvFwwoBDPi0jMtdf/PwIDAQAB"]
Proper records repopulated after
2026-08-21T20:58:09Z INFO DNS record created (dns.record-created) hostname = "v2-ed25519-20260802._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=ed25519; h=sha256; p=3m7r093JS4J1yaoP0I0tf93nocaF4MKWuOVdaLC+73Y="]
2026-08-21T20:58:09Z INFO DNS record created (dns.record-created) hostname = "v1-rsa-20260801._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=rsa; h=sha256; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAuP7HzC9smvkVEc7+U+lDy+ns9wZeG2NLINUJWK10jI7Rcs4WiPu4uLNbojMQMcJN/HjAGY0D0HtaCtCm08JDuUNCALFMD+u7InJuPuCdXNWVEGgRhpMVT42BAeJXZftebc9cEvCUyLq8tWSQVzOfJ64ofkryKU1qTxfBJMVVIL5C3lXw6nXlk6xAiZJrNydh0OUiMUWZW8SHq8bzrCNSdc4oi5wVbF9CCRWiU56+3XasopkgRW0hbT6yRDsghEqG2hP5h57R0sV21CM96XG7i9PLa2BnhyfsdAohPdBidJNfZ/JPQqGS5qbd/7svWY3lUywhmYkkNl7QvfLfnFvtlQIDAQAB"]
2026-08-21T20:58:13Z INFO DNS record created (dns.record-created) hostname = "v1-ed25519-20260801._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=ed25519; h=sha256; p=VXn3t1vPMrq0Jy9E2Wo2Q4tgebMkrQ7wOi0DASxfFeg="]
2026-08-21T20:58:13Z INFO DNS record created (dns.record-created) hostname = "v2-rsa-20260802._domainkey.example.ca.", details = "example.ca", type = "TXT", value = ["v=DKIM1; k=rsa; h=sha256; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAyKn2rCg2Nfjt7pFe1CM1AVitIJcqElsBOP81SZLv4I6Si8100zV90HAFeE2CkEXS1S8ty2RxVS+pR+/oMjWiI9SUsQtUIRZcF43I2zbldDehAy7RUbCkAWx3wJUDHQpGd4qHuFLyCmuHKg03EfW+kXBbs/bVlL1NFODAHl7dux8XVGfQtD9Ti1VvkzzkWDAtpnHNx/RWdvbnO38IRJl8XeA7Kmw8Zgv8sgaQM4+9qeCI55St9hEXgP+wkdnjj/a85vmRo11lUxmE8UDBOOxewfk9sYz/bnYXtAad3TleDkviybeJ6KiN26asy3hRdU8PwCx/64OFqSz5xeNMBZx+WwIDAQAB"]
v0.16.18
