# pacman -Qi stalwart
Version : 0.16.8-1
Description : Stalwart mail and collaboration server
Architecture : x86_64
URL : https://stalw.art
Licenses : AGPL-3.0-only
Groups : None
Provides : None
Depends On : glibc rocksdb stalwart-webadmin libgcc libgcc_s.so=1-64 libstdc++ libstdc++.so=6-64
Optional Deps : stalwart-cli: management CLI [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 81.43 MiB
Packager : George Rawlinson <[email protected]>
Build Date : Sun 07 Jun 2026 11:45:40 PM UTC
Install Date : Thu 11 Jun 2026 02:32:44 AM UTC
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
# head -n100 *
==> config.env <==
# Environment variables for the Stalwart service.
# Uncomment and edit an entry to override its default.
# Override the hostname used in HTTP responses
#STALWART_HOSTNAME=mail.example.com
# Override the HTTPS port used in HTTPS responses
#STALWART_HTTPS_PORT=8080
# Enable bootstrap / recovery mode on startup. Accepted: 1, true. Default: false.
#STALWART_RECOVERY_MODE=true
# Log level while in recovery mode. Default: info.
#STALWART_RECOVERY_MODE_LOG_LEVEL=debug
# HTTP port used in recovery mode. Default: 8080.
#STALWART_RECOVERY_MODE_PORT=9090
# Fixed administrator credentials — format: username:password
# Default: a temporary random password is generated and printed to the logs.
#STALWART_RECOVERY_ADMIN=admin:changeme
# Cluster role assigned to this node. Must match a role name defined in the
# cluster registry. Leave unset for a standalone (non-clustered) deployment.
#STALWART_ROLE=primary
# Push-notification shard this node is responsible for, when running in a
# cluster.
#STALWART_PUSH_SHARD=1
==> config.json <==
"@type": "Sqlite",
"path": "/var/lib/stalwart/stalwart.sqlite3"
# journalctl --unit stalwart -I
Jun 11 02:38:43 chargeitservices.com systemd[1]: Started Stalwart Mail Server.
I tried uncommenting STALWART_RECOVERY_ADMIN and following the information in the docs Linux / MacOS | Stalwart
There was no bootstrap information. The username/password I set does not appear to work on localhost:8080. I’m out of ideas and could use some help.
Some kind of diagnostic information in the journal.
Completely inaccessible with no diagnostic information.
Frest install of 0.16.8-1 on arch.
SQLite
MySQL
SQL
