I have generated a Vapid private key online and locally. Both keys are not accepted by the webui.
The Online version I used was VAPID Key Generator - Generate Web Push Keys | RandomKeygen.
The local command was : openssl ecparam -name prime256v1 -genkey -noout -out vapid_private.pem
When I reload the server settings I get the following error message: Action failed
Invalid Web Push VAPID key: PKCS#8 ASN.1 error: PEM error: unexpected PEM type label: expecting “PRIVATE KEY”
So, can anybody tell me or describe how to generate a valid VAPID key for Push notifications?
Thanks in advance
The error is a format mismatch: openssl ecparam -genkey (and the online randomkeygen base64 values) produce a SEC1 key labelled -----BEGIN EC PRIVATE KEY----- or a raw application-server key, but Stalwart wants a PKCS#8 key labelled -----BEGIN PRIVATE KEY----- on the P-256 curve with named-curve encoding.
Use vapid_pkcs8.pem, and paste the whole -----BEGIN/END PRIVATE KEY----- block with no leading BOM or whitespace. Worth knowing: the server generates a valid VAPID key automatically on first startup, so you may already have one under the JMAP push settings and not need to make one at all. (See the VAPID key quirks thread for the same encoding gotchas.)
