Outbound rate limiting expressions inverted?
I have created a outbound rate limit for a specific queue queue_name == 'local' using the domain as a key And a rate limit of 5 messages per second.
When testing this, i submitted 1000 email, which should process just over 3 minutes based on the rate rules. However they all sent in roughly 8 seconds, completely disregarding the rate limit.
When inverting the expression too queue_name != 'local' then the rate limit took effect.
The emails sent should have been processed over the period of roughly 3 minutes.
All emails processed in 8 econds.
  1. Create a outbound rate limit
  2. Add an expression for the rate limit (such as a queue)
  3. observe the rate limit does not take effect
  4. Invert the expression
  5. Observe the rate limit now takes effect
Binary (Windows)
I am tinkering around with creating low priority queues with outbound rate limits.
The logic isn’t inverted: an outbound rate limit applies when its expression evaluates to true. What’s tripping this up is what queue_name means. It’s the virtual queue the message was assigned to (the defaults are local, remote, dsn and report), not a “was this local delivery” flag.
Your 1000-message test went to external recipients, so those messages are in the remote queue. queue_name == ‘local’ never matches them, so no limit applies; queue_name != ‘local’ matches them all, so the limit kicks in. That’s exactly the behavior you saw. Use queue_name == ‘remote’ to throttle outbound-to-internet (or whatever custom queue your queue strategy assigns)
They werent external. They are on the local queue. My testing environment has no external sending capabilties.
stalwart.2026-07-12.txt (2.4 MB)
Fixed in v0.16.14 (not yet released). The issue was that the queue_name variable was not reachable from the rate limiters.
