Running stalwart-migrate run on Ubuntu 24.04, arm64 results in segfault.
No segfault!
Segfault!
Just follow the regular migration - prepare, then run.
Offsets
Frame Address in core vaddr (for symbols) File offset (for bytes on disk)
#0 (PC) 0xc527b0b9b074 0x3b9b074 0x3b8b074
#1 0xc527b0a9f414 0x3a9f414 0x3a8f414
#2 0xc527b0a9e8a0 0x3a9e8a0 0x3a8e8a0
#3 0xc527b0a9cfd0 0x3a9cfd0 0x3a8cfd0
#4 0xc527b0a9cea4 0x3a9cea4 0x3a8cea4
#5 0xc527b09799d4 0x39799d4 0x39699d4
From coredump:
(gdb) bt
#0 0x0000c527b0b9b074 in ?? ()
#1 0x0000c527b0a9f414 in ?? ()
#2 0x0000c527b0a9e8a0 in ?? ()
#3 0x0000c527b0a9cfd0 in ?? ()
#4 0x0000c527b0a9cea4 in ?? ()
#5 0x0000c527b09799d4 in ?? ()
#6 0x0000c527aee30b38 in ?? ()
#7 0x0000c527af709180 in ?? ()
#8 0x0000c527af708524 in ?? ()
#9 0x0000c527af70c9a0 in ?? ()
#10 0x0000c527b02a9940 in ?? ()
#11 0x0000e87c5e1a582c in start_thread (arg=0xe87c5e3b6b80) at ./nptl/pthread_create.c:447
#12 0x0000e87c5e20bb4c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone3.S:76
(gdb) info threads
Id Target Id Frame
1 Thread 0xe87c30f9e840 (LWP 112312) 0x0000c527b0b9b074 in ?? ()
2 Thread 0xe87c3fdee840 (LWP 112417) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c3fde7658) at ./nptl/futex-internal.c:57
3 Thread 0xe87c3d38e840 (LWP 112470) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
4 Thread 0xe87c4c3cd840 (LWP 112415) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c4c3c6658) at ./nptl/futex-internal.c:57
5 Thread 0xe87c3cf9e840 (LWP 110677) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
6 Thread 0xe87c3f7ee840 (LWP 111905) 0x0000e87c5e20be74 in __GI_epoll_pwait (epfd=3, events=0xc527bd263db0, maxevents=1024, timeout=10624, set=0x0)
at ../sysdeps/unix/sysv/linux/epoll_pwait.c:40
7 Thread 0xe87c4fffe840 (LWP 110267) 0x0000e87c5e1a1d70 in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xc527bd254668) at ./nptl/futex-internal.c:57
8 Thread 0xe87c3d7ae840 (LWP 112468) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
9 Thread 0xe87c3d59e840 (LWP 112469) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
10 Thread 0xe87c5deae840 (LWP 110263) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
11 Thread 0xe87c31fbe840 (LWP 112314) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c31fbd6a8) at ./nptl/futex-internal.c:57
12 Thread 0xe87c3fffe840 (LWP 112416) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c3fff7658) at ./nptl/futex-internal.c:57
13 Thread 0xe87c317ae840 (LWP 112313) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c317ad6a8) at ./nptl/futex-internal.c:57
14 Thread 0xe87c32fde840 (LWP 111083) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
15 Thread 0xe87c3fbde840 (LWP 112418) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
16 Thread 0xe87c5e0be840 (LWP 110262) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
17 Thread 0xe87c3dfbe840 (LWP 111084) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
18 Thread 0xe87c4c5dd840 (LWP 112324) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
19 Thread 0xe87c17ffe840 (LWP 112311) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0xe87c17ffddd8, op=393,
expected=0, futex_word=0xc527bd24e408) at ./nptl/futex-internal.c:57
20 Thread 0xe87c3e7ce840 (LWP 111085) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
21 Thread 0xe87c3efde840 (LWP 111086) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
22 Thread 0xe87c5d90d840 (LWP 110264) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xc527bd263a68) at ./nptl/futex-internal.c:57
23 Thread 0xe87c5d0fd840 (LWP 110265) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xc527bd263a6c) at ./nptl/futex-internal.c:57
24 Thread 0xe87c5c8ed840 (LWP 110266) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
25 Thread 0xe87c3c78e840 (LWP 112471) 0x0000e87c5e1a1d6c in __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0,
futex_word=0xe87c3c7812e8) at ./nptl/futex-internal.c:57
26 Thread 0xe87c5e3b6440 (LWP 110261) syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
27 Thread 0xe87c4c7ed840 (LWP 112315) 0x0000e87c5e207d4c in __GI_munmap () at ../sysdeps/unix/syscall-template.S:120
(gdb) p $_siginfo
$1 = {si_signo = 11, si_errno = 0, si_code = 1, _sifields = {_pad = {240, 0 <repeats 27 times>}, _kill = {si_pid = 240, si_uid = 0}, _timer = {si_tid = 240,
si_overrun = 0, si_sigval = {sival_int = 0, sival_ptr = 0x0}}, _rt = {si_pid = 240, si_uid = 0, si_sigval = {sival_int = 0, sival_ptr = 0x0}},
_sigchld = {si_pid = 240, si_uid = 0, si_status = 0, si_utime = 0, si_stime = 0}, _sigfault = {si_addr = 0xf0}, _sigpoll = {si_band = 240, si_fd = 0},
_sigsys = {_call_addr = 0xf0, _syscall = 0, _arch = 0}}}
(gdb) p/x $_siginfo._sifields._sigfault.si_addr
$2 = 0xf0
(gdb) x/6i $pc-8
0xc527b0b9b06c: clrex
0xc527b0b9b070: mov x9, x8
=> 0xc527b0b9b074: ldr x8, [x8, #240]
0xc527b0b9b078: cmp x8, x19
0xc527b0b9b07c: b.ne 0xc527b0b9b070 // b.any
0xc527b0b9b080: str x22, [x9, #240]
(gdb) info registers
x0 0x85e4 34276
x1 0xe87c30f9d5c0 255620095268288
x2 0xe87c30f9d2e8 255620095267560
x3 0x1 1
x4 0x0 0
x5 0xc527bdb9ad90 216774477458832
x6 0xfffffffffffffff0 -16
x7 0x3 3
x8 0x0 0
x9 0x0 0
x10 0x30 48
x11 0x5 5
x12 0x0 0
x13 0x0 0
x14 0xfffffffffffff000 -4096
x15 0x0 0
x16 0x1 1
x17 0xe87c5e1aa5c4 255620852393412
x18 0x5 5
x19 0xe87c4c3c6570 255620552615280
x20 0xc527bdb9b0c0 216774477459648
x21 0x21080 135296
x22 0xe87c3c781200 255620288090624
x23 0xe87c3c781200 255620288090624
x24 0xe87c4c3c6570 255620552615280
x25 0xe87c4c3c6570 255620552615280
x26 0xe87c30f9d619 255620095268377
x27 0x0 0
x28 0xc527bdb9b280 216774477460096
x29 0xe87c30f9cf30 255620095266608
x30 0xc527b0a9f414 216774258324500
sp 0xe87c30f9cf30 0xe87c30f9cf30
pc 0xc527b0b9b074 0xc527b0b9b074
cpsr 0x80001000 [ EL=0 BTYPE=0 SSBS N ]
fpsr 0x10 [ IXC ]
fpcr 0x0 [ Len=0 Stride=0 RMode=0 ]
tpidr 0xe87c30f9ef80 0xe87c30f9ef80
tpidr2 0x0 0x0
(gdb) info proc mappings
Mapped address spaces:Start Addr End Addr Size Offset objfile 0xc527ad000000 0xc527addc3000 0xdc3000 0x0 /usr/local/bin/stalwart-migrate 0xc527addd2000 0xc527b0f87000 0x31b5000 0xdc2000 /usr/local/bin/stalwart-migrate 0xc527b0f96000 0xc527b11e7000 0x251000 0x3f76000 /usr/local/bin/stalwart-migrate 0xc527b11f6000 0xc527b1219000 0x23000 0x41c6000 /usr/local/bin/stalwart-migrate 0xe87c5e0c0000 0xe87c5e0c1000 0x1000 0x0 /usr/lib/aarch64-linux-gnu/libdl.so.2 0xe87c5e0c1000 0xe87c5e0df000 0x1e000 0x1000 /usr/lib/aarch64-linux-gnu/libdl.so.2 0xe87c5e0df000 0xe87c5e0e0000 0x1000 0xf000 /usr/lib/aarch64-linux-gnu/libdl.so.2 0xe87c5e0e0000 0xe87c5e0e1000 0x1000 0x10000 /usr/lib/aarch64-linux-gnu/libdl.so.2 0xe87c5e0f0000 0xe87c5e0f1000 0x1000 0x0 /usr/lib/aarch64-linux-gnu/libpthread.so.0 0xe87c5e0f1000 0xe87c5e10f000 0x1e000 0x1000 /usr/lib/aarch64-linux-gnu/libpthread.so.0 0xe87c5e10f000 0xe87c5e110000 0x1000 0xf000 /usr/lib/aarch64-linux-gnu/libpthread.so.0 0xe87c5e110000 0xe87c5e111000 0x1000 0x10000 /usr/lib/aarch64-linux-gnu/libpthread.so.0 0xe87c5e118000 0xe87c5e120000 0x8000 0x0 /opt/container-data/stalwart/migrate-state/state.sqlite-shm 0xe87c5e120000 0xe87c5e2ba000 0x19a000 0x0 /usr/lib/aarch64-linux-gnu/libc.so.6 0xe87c5e2ba000 0xe87c5e2cd000 0x13000 0x19a000 /usr/lib/aarch64-linux-gnu/libc.so.6 0xe87c5e2cd000 0xe87c5e2d0000 0x3000 0x19d000 /usr/lib/aarch64-linux-gnu/libc.so.6 0xe87c5e2d0000 0xe87c5e2d2000 0x2000 0x1a0000 /usr/lib/aarch64-linux-gnu/libc.so.6 0xe87c5e2e0000 0xe87c5e365000 0x85000 0x0 /usr/lib/aarch64-linux-gnu/libm.so.6 0xe87c5e365000 0xe87c5e37f000 0x1a000 0x85000 /usr/lib/aarch64-linux-gnu/libm.so.6 0xe87c5e37f000 0xe87c5e380000 0x1000 0x8f000 /usr/lib/aarch64-linux-gnu/libm.so.6 0xe87c5e380000 0xe87c5e381000 0x1000 0x90000 /usr/lib/aarch64-linux-gnu/libm.so.6 0xe87c5e384000 0xe87c5e3ab000 0x27000 0x0 /usr/lib/aarch64-linux-gnu/ld-linux-aarch64.so.1 0xe87c5e3c2000 0xe87c5e3c4000 0x2000 0x2e000 /usr/lib/aarch64-linux-gnu/ld-linux-aarch64.so.1 0xe87c5e3c4000 0xe87c5e3c6000 0x2000 0x30000 /usr/lib/aarch64-linux-gnu/ld-linux-aarch64.so.1
stalwart-migrate status --state ./migrate-state
State database: ./migrate-state/state.sqlite
tool_version 1.0.1
edition enterprise
source_def_hash eac838c9ccd547f73f088f438c223eb6
target_def_hash 7fbcc15151bc4da024cd6b880c74bbd0
target_schema_version 7
categories settings,principals,mail,calendars,contacts,files,sieve,identities,push_subscriptions,spam_samples,reports,archive,spam_model,queue,tasks,telemetry
created_at 2026-10-27T10:19:24Z
source_store directory /opt/container-data/stalwart/data
target_claim 693c6a5a52f1b3766bbfdca4b163a2da
claim_generation ffe6637f34a8633499680d1bee91a23a
claim_generation_pending ffe6637f34a8633499680d1bee91a23a
final_done not done
Accounts: 8
done 4
full 4
Recent runs:
#12 incremental running started 2026-10-27T11:02:19Z
#11 incremental interrupted started 2026-10-27T10:59:05Z
#10 incremental interrupted started 2026-10-27T10:58:42Z
#9 incremental interrupted started 2026-10-27T10:40:31Z
#8 incremental interrupted started 2026-10-27T10:38:27Z
Reports in the latest run:
none
Reports in all runs:
info changed 23
warning dropped 61
