Updating Hostname in System Sieve Interpreter fails
When updating the messageIdHostname in SieveSystemInterpreter, it returns The data did not pass validation. else: Required.
This happens via the admin interface and the API.
The value should be updated without an error
The error is returned: The data did not pass validation. else: Required
  1. In the admin interface, go to Settings > Sieve > System Interpreter
  2. Provide a value in the Hostname option
  3. Hit Save.
  4. The failure should appear
Let me look into this validation issue with the Sieve System Interpreter hostname setting.
This has been fixed on the main branch. The fix will be included in v0.16.8.
