Default value missing for defaultReturnPath of SieveSystemInterpreter
The Return Path of the System Sieve Interpreter is required, but it is empty by default. So any changes to that page (admin/Settings/x:SieveSystemInterpreter) can’t be saved in the web interface.
There should be a default value provided for this.
No default value is set for the return path of the system sieve interpreter
A default value is set for the return path of the system sieve interpreter
v0.16.7
This was a real validation bug: defaultReturnPath was treated as required, so an empty value blocked saving the page. It’s fixed in 0.16.8, the field is now an optional expression and an empty value is allowed. Updating from 0.16.7 resolves it.
