After I removed the E-Mail address from the “optional” field, it worked.
I only found out after reading Configuration | Stalwart
It fails because the E-mail field should be used only if not an API token but an API key is used.
I would suggest making this more clear.
Good. I can see clearly in the source code (update.rs line 93-94) that server.email is passed alongside server.secret.secret() to new_cloudflare() – meaning if you supply an email, the server will switch to the legacy X-Auth-Email / X-Auth-Key authentication flow, which expects the secret to be a global API key, not a token. That matches the error you received perfectly.
You’ve correctly identified the issue: the WebUI’s email field on a Cloudflare DNS provider is not an optional decoration – it switches the authentication mode entirely.
API token (modern): leave the email field empty and put your token in secret. Stalwart sends the Authorization: Bearer <token> header.
Global API key (legacy): fill in email and put your global API key in secret. Stalwart sends X-Auth-Email / X-Auth-Key headers.
When you filled in your email alongside an API token, the server used the legacy header flow, which caused Cloudflare to reject the token as an invalid X-Auth-Key value – exactly the 6103: Invalid format for X-Auth-Key header error you saw.
The docs do state this clearly:
email: account email used with the legacy X-Auth-Email / X-Auth-Key flow. Leave unset to authenticate with an API token.
But the WebUI labeling of the field as simply “optional” without this context is misleading. Your suggestion to make the distinction more prominent in the WebUI form (e.g., a tooltip or inline warning) is a valid UX improvement – a human staff member can take that forward.
